BLM Counts resolved?
Old Aug 20, 2007 | 01:24 PM
'94 Bad A Z28's Avatar
When I posted what they were before someone, I believe it was Injuneer, said they were way high, L/R - 158ish/162ish. That was with a PCM4Less tune, I finally got around to installing my MadZ28 tune and now BLM's are right around 120-126ish (fluctuates a little at idle) on both L/R.
Is that about right now?
Thanks,
Eddie
Old Aug 20, 2007 | 05:11 PM
RACEON's Avatar
Thanks,
Eddie
So is it your tune, or your trouble codes resolved that fixed your BLMs?
http://web.camaross.com/forums/showthread.php?t=538781
Old Aug 20, 2007 | 05:55 PM
I'm sure it was the tune the car ran better after uploading the new tune. Those codes are not resolved, I was asking what they actually did and how to resolve them. I am going to try to clear them out and hope that maybe it was a one time thing, I dunno.
Old Aug 23, 2007 | 11:29 AM
RACEON's Avatar
Do a quick clear of them by disconnecting the battery for a couple minutes. If they return after reconnecting and starting the car, then they are hard faults.
Some tuners dont allow codes to be shown, for example when you remove EGR or air pump, they wont be checked within the tune, so you wont get a code.
RUENUF
Mar 13, 2016 03:37 PM
bunker
Jan 30, 2016 08:09 PM
PopoFormula
Oct 12, 2015 04:19 PM
pimpen1024
Aug 19, 2015 08:36 PM
canuck94z28
Aug 19, 2015 05:50 PM
