BIG VOLTAGE drop on 1,4,6,7 - Anyone know where power splice is in harness??
I was wondering if anyone with a lt1s had a wiring problem with certain injectors? I am trying to find where the 2 splices are for the 2 injecter power fuses. I have a pretty big voltage drop at injectors 1,4,6,7 but not at the fuse or close bye wiring. Dont want to disturb the connection problem, just wondering if anyone has traced their splices for either side? And where did you find it in the harness? I have been fitting a mismatch len and rich that is intermitent, finely found the case . If you have any whereabouts of the splises please let me know.
Thanks!
Pat
Thanks!
Pat
The power on the pink wire to the injectors in question runs through connector C100. The 10 pin connector located near the PCM. Then it goes to the splice located between injector 3 and 5. Check the connector as well as the splice.
