Beginner problems with LT1 Edit
Old May 2, 2004 | 09:55 PM
Ponyhntr's Avatar
I am trying to read my PCM for the first time using LT1 Edit and for whatever reason the program cannot connect with the PCM. There is also a message on the screen that there is a READ-ONLY cable installed, and NOT to try to program the PCM. I bought the software and PCM used, so Idon't know if I'm doing something wrong or not. Could it be that my laptop doesn't have a serial port and I had to buy a serial-to-USB adapter? I have heard that some adapters won't work. The adapter works flawlessly with Autotap, but could it not work with LT1 Edit? Any suggestions, guys?
Thanks!
Old May 3, 2004 | 03:17 AM
96TurboTA's Avatar
The cable hardware is locked to the vin of the original pcm the LT1_edit was bought for. You need to contact carputing.com and have them add your vin to the license.
Old May 3, 2004 | 07:22 AM
sabre81's Avatar
what kind of cable? also i dont like usb to serial adapters for programming a pcm knowing windows and drivers. Too risky. I would get a serial port for you laptop. Your need a port replicator. You can either plug into a special port on your laptop depending on the brand of laptop, OR you can buy a usb port replicator. the usb port replicator actually creates real serial ports instead of converting the data bits from serial to usb.
Old May 3, 2004 | 08:46 AM
Ponyhntr's Avatar
I Have the original PCM that it was bought for.
Old May 3, 2004 | 08:49 AM
Ponyhntr's Avatar
I think it's an IOGEAR, or something like that-got it from Best Buy. Where can I get one of those port replicators? I have a new M505 Gateway laptop. Thanks for the help so far.
Old May 3, 2004 | 08:58 AM
sabre81's Avatar
i bought mine off ebay. They also have them at compusa, and they should have them at best buy also.
Heres abn example on ebay
Here
Port replicators usually always have a serial port, a paralell port. Look for one with both just to be sure your not getting a usb to serial converter.
Old May 3, 2004 | 11:09 AM
Ponyhntr's Avatar
Ok, thanks for the example I know what you're talking about now. So will this solve my problem? I take it that the adapter is what's causing my problems? Thanks for all your help!
Old May 3, 2004 | 11:20 AM
sabre81's Avatar
yes those usb adapters were really made for devices like mice and keyboards and joysticks and crap. Tend to be a pain for things like this.
good luck
Old May 4, 2004 | 02:52 PM
Z28WannaB's Avatar
Just get a hexidecimal editor and change the VIN number within the program and recompile. Wah-la! At least I think that should work.
- Z28WannaB
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
Bando
Aug 2, 2002 02:18 PM
