Auto trans programing help needed
Old Apr 24, 2010 | 03:01 PM
ayers1967's Avatar
I'm working on 95 LT1 with auto trans . The ECM went bad so we got a used one . I reflashed it with a stock program using Tunner Cats . The car will shift from 1 to 2 just find but then goes right into 4th at about 35 MPH . The car worked find before this. I have a paper copy of the program. I have looked over it and can't see anything right off. I told the ECM what gear ratio the cars has so that's not it. Could something in the ECM switch table or ECM constants table be causing this? I'm new to the tuning part of these cars any help would be great !
Old Apr 26, 2010 | 10:24 AM
bobdec's Avatar
Can you e-mail me a copy of the .bin file , I'll take a quick look at it. Are you sure it's a '95 A4 .bin not an '94 as there is a difference in the TCC PWM solenoid code. You can also download TTS Datamaster EE for 20 free logs and see if you have any transmission DTC errors and if the shift encode is working correctly.
Old Apr 28, 2010 | 07:00 AM
my954mula's Avatar
Don't be surprised if it isn't in the tune somewhere. A mis-adjusted TV (throttle valve) cable will do that also.
Old Apr 28, 2010 | 08:40 AM
ayers1967's Avatar
You were dead on ! Thanks .
blown94
May 3, 2015 12:48 AM
jb4xx
Feb 2, 2015 10:00 PM
rockync7
Jan 1, 2015 05:10 AM
Sarahrope64
Nov 27, 2014 11:17 AM
mjcent922
Jul 27, 2002 12:42 PM
