97 File in 96 PCM?
I have a 97 PCM running my 96 Z28. Should be fine...however I ran into the same thing you are...with it complaining about versions. I think you can somehow "force full program" it, but I didn't want to do that and took a different route.
I opened the program I wanted in the PCM and then compared it to the program in the PCM(using the compare differences). Then I printed out the differences and changed the tables accordingly. Longer way around the block, but it safely works.
I ended up changing my pcm to a 97 pcm. That way I could safely upload the 97 file.
I also got in touch with Bryan Herter from PCM for less, who has lots of experience on this subject and stated the following:
Question:
I wanted to know if I can upload the 97LT1 file into the 96 PCM.
BH:
If it is a manual car, yes they are interchangeable, if it is an automatic they often throw false codes if you do that swap and I would stick with a 97
Question:
BH:
whitehooptie
Aug 10, 2015 07:02 AM
88IROC_Z
Jul 22, 2015 11:38 PM
NewsBot
Jul 8, 2015 06:47 PM
