'95 OBDII problem
'95 OBDII problem
I have a '95 with an OBDII. I bought a scantool and plugged it in but it just read that there was an error. I hooked it up to my friends '99 LS-1 which is also an OBDII and the thing worked. I have heard someone call the '95 the bastard year because it is the first year of the OBDII but the same engine and it doesn't belong and has a lot of problems, has anyone else encountered this problem or has anyone heard about this?
Yep sounds like an OBDI with and OBDII connector. To be sure check this site out and compare the ones there to the one you have:
http://www.mastach.com/index.php?module=aldlconn&l=en
Laters
Tails
Laters
Tails
Originally posted by Greg_pl
They're right, although you have 16 pin connector (like OBDII) it's still a OBDI car. '95 is a perfect year for an fbody, still an easy OBDI (cheaper to tune) and a vented opti.
I'm in the same boat. I have a '95 car that I thought was OBDI but am now confused beyond all reason... It's definitely an OBDII connector, but How the hail do you get the codes out of it if there isn't an OBDI scanner with an OBDII connector???
Originally posted by tjwong
Its definitely a OBD1 computer with a OBD2 connector. There were no OBD2 PCMs in any 1995 car. There were however plenty of OBD2 diagnostic connectors in that year.
