94/95 .bin file work in a 96/97 pcm?
Old Aug 1, 2005 | 03:43 PM
TAChad's Avatar
I'm using tunercat and i have both the definition files for the 94/95 lt1 and the 96/97 lt1 obdII pcms. I was wanting to make sure that it would work if i downloaded a .bin file for the 94/95 and used it in the 96/97?? All i really need is the tranny tables shift points and gear calibration....so should i copy it from the 94 and paste it in the table for the 96/97? thanks
Chad
Old Aug 3, 2005 | 09:44 AM
tjwong's Avatar
Re: 94/95 .bin file work in a 96/97 pcm?
Chad, it will not work. Don't try it, and I doubt that the system would even allow you to attempt to load it. Look at the file sizes, there is a big difference between the OBD1 and OBD2 file size.
Old Aug 3, 2005 | 10:37 AM
TAChad's Avatar
ok, i didnt think it would be an easy thing to do...i did notice a lot of differences in the drop down menus and stuff. thanks for the reply
Chad
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 21, 2015 06:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
NewsBot
Dec 3, 2014 12:30 PM
