93 SC bin files
Hey everyone,
I'm looking for a 93 bin file made for a supercharged application. Right now I'm using the stock injectors; however, I will be going to at lest 30 SVOs.
I'm still really new to tunercat, hell I'm new to tuning in general!
And would really like some help. I think that if some one could send me a bin file that I can look at in tunercat -- that has a very similar set up as my own -- I maybe able see what’s going on and understand it a little better. I'm not going to lie, and tell everyone that I will not use it in my car, because I will; I might not even change it if it works better than what I have going now. But I am interested in learning, and will tweak on the file at lest a little bit, just to see if I can improve it at all.
Thank you all in advance,
93z, powerdyne 6#, hard-intake mod, Hi-6R w/boost retard, hooker headers, carsound CAT, 3" catback, Mac lowering springs, RKsport ajdustable shocks, TransGo shift kit, 2800 vig, CSI water pump, TB bypass, 160* thermostat.
[This message has been edited by djlup (edited August 14, 2002).]
And would really like some help. I think that if some one could send me a bin file that I can look at in tunercat -- that has a very similar set up as my own -- I maybe able see what’s going on and understand it a little better. I'm not going to lie, and tell everyone that I will not use it in my car, because I will; I might not even change it if it works better than what I have going now. But I am interested in learning, and will tweak on the file at lest a little bit, just to see if I can improve it at all.Thank you all in advance,
You do not need 30 lb injectors if your setup is what is below in your sig. You can get away with 24 lb injectors. SOrry I do not have any bin files to help you out. I am currently running a Speed Pro in my 93 Camaro
Thanks for the info, I just figure that I will be wanting to add more power later and should get some injectors that will last me. Someday I plan on installing a 7" crank pulley!
Any body out there that can help me out?
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
tommalcolm
Sep 11, 2015 03:39 PM
