93 pcm to later style
Old Oct 1, 2002 | 07:10 PM
junior7959's Avatar
Does anyone know how tuff it would be to switch from a 93 pcm to a 95 or later? What parts would work or not work with the new pcm? Any imput would help
Old Oct 1, 2002 | 08:07 PM
Deadcarny's Avatar
john, it would have to bea 94 or 95 PCM, since the 96 and 97 are OBD II. i am not sure what is needed, though.
Old Oct 1, 2002 | 08:20 PM
Alvin@pcmforless.com's Avatar
Why would you want to do that? A speed density car is easy to tune and very versitile.
Most aftermarket ECM are a speed density setup
Old Oct 1, 2002 | 08:24 PM
Deadcarny's Avatar
i believe he is not wanting to have to burn chips....
isn't there a way to tune a 94-95 PCM in speed density mode so it does not need a MAF?
Old Oct 1, 2002 | 08:28 PM
Burning chips is not a problem at all. People are too afraid of it. The way I see it its the way to go.
Chips only cost around $5.50 a piece where as a new 94-95 computer cost how much ???? I would think $100 + easy. Plus too figure out the headache of swaping everything including a transmission possibly
You can get a very decent programmer for $150!
Old Oct 1, 2002 | 08:33 PM
Deadcarny's Avatar
post the links to where he could get the tuning and burning software/hardware.
Old Oct 1, 2002 | 08:39 PM
www.tunercat.com
www.xtronics.com (you need the pocket programmer 2)
www.akmcables.com (you need a cable and TTS datamaster)
www.digikey.com (get a amtel AT29C256 chip, I've never toasted any and they only cost $5.50 a piece)
don't worry about an UV eraser they are not needed if you use a AT29C25 chip
sleeperZ96BT
Sep 9, 2015 08:28 AM
NewsBot
Aug 3, 2015 02:40 PM
88IROC_Z
Jul 22, 2015 11:38 PM
Jul 10, 2015 02:23 PM
CARiD
Jul 7, 2015 08:19 AM
