26# injectors
Old Sep 5, 2002 | 04:15 PM
TSearsJr's Avatar
Question 26# injectors
Does anyone know how to tune for 26# injectors using tunercat. I ajusted my contant table to 26# but what else.
Thanks Terry
95 Black Z28 T-top
CAI, LT4 Knock, 2 1/2 Dual Exaust, 58mm ThrottleBody, EGR!
Old Sep 5, 2002 | 04:33 PM
CanadianZ's Avatar
Post
What 26# injectors do you have?? If you mean 24# SVO's then the injector constant should be set at 26.46#'s or so.
CanadianZ
Old Sep 5, 2002 | 04:37 PM
Dr.Mudge's Avatar
Post
SVOs or LS1 injectors? LS1 injectors are used with a higher fuel pressure, so they are just a waste of cash if you've got an LT1.
Old Sep 5, 2002 | 04:51 PM
TSearsJr's Avatar
Post
My old injectors went bad (109,000 on them) I got a deal on them. They are gm #26 injectors. Did not know of differnt fuel pressure. The car runs just not the same.
Old Sep 6, 2002 | 03:27 PM
Dr.Mudge's Avatar
Post
Try going back to a stock injector constant and see how the BLMs are, how are they now?
Old Sep 6, 2002 | 06:57 PM
TSearsJr's Avatar
Post
Ran the car today set to 25# constant 40 vac on 48 vac off. ran from 140 to 128 blm. the left blm seems to be +2 off compared to the right ie. 130 left 128 right BLM
Old Sep 7, 2002 | 08:10 PM
TSearsJr's Avatar
Post
Set constant to 24lbs with fuel pressure set to 40 vac on 48 vac off. My blm reads 143left 148right idle rpm set 650, Iac 29, TPS .71
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
