2 Bar Stock PCM Speed Density Tune for >6psi (Forced Induction)
Its really exciting seeing you guys get this far with this.
I had a issue in my 93 LT1 calibrations with the airflow modes not matching at all with the o2 threasholds. The result was the car was constantly trying to trim itself way to lean. I eventually plotted O2 sensor voltage with WBAFR and manipulated the threashold tables to tune for the desired closed loop AFR>
If your using some or part of my original file I wonder If I may be partially responsible for the re-start problem since Im having the same symptoms and I do remember messing with some of those settings... there's a bunch of settings for this in Tunercat which I messed with in the beginning.
If your not using it then these settings need to be adjusted, either way Tunercat has settings for these.
If you'll notice when you shut the car off then soon try to re-start sometimes it tends to fire just a bit, usually at this point I let the key go then it stumbles then stalls then I have to hold the key for 3-4 seconds and it will start fine. During the 3-4 seconds of crank if I tap the gas it will fire right up and run fine with no recovery... if it were flooded or cranking too rich then there would be some rough running for a few seconds to clean out the extra fuel, in my case once it's running it's good which makes me think it's leaning out upon re-start.
Now, in tunercat there are settings which I think hold the key to fixing this problem (comparing hot coolant temps to colder ones which seem to startup fine)
1) Crank AFR vs DIst Reference... (jumps from 9AFR to 12AFR from 68 to 80c...)
2) Extended Crank AFR vs DRP... (jumps from 6.3AFR to 12AFR from 32 to 40c)
3) Prime Pulse Width vs Coolant Temp... I think this is what gives you the very first blast of fuel... or the very first fire up.. I notice the actual initlal fire force uppn startup is weaker in warm temp than cold.. cold temps are actually pretty fierce on the initial crank fire up... somethign like when cold (below 70F) the first 1/2 second of cranking it revs to 1200-1300 instantly like it skipped all the lower RPMs
sounds cool like it really wants to start then RPM's come down instantly to whatever else controls it.. maybe Initial Startup AFR Enrichment vs Coolant temp? (#5 below)4) Added Prime Pulse Width Enable vs coolant - I thin this is "Extra" and not used unless engine does not start in allowed time according to #5 (liike a person deciding to start pumping the gas faster or getting out and closing the choke on a carburated car)
5) Added Prime Pulse Enable - I think this enables the above calculation (#4)
6) Initial Startup AFR Enrichment vs Coolant....
I think since the intial fire actually happens under all temps then 1-3 are ok, but #4 and 5 might need some adjustment? Seems like the settings for cold (0F-~150F) are ok or good enough since it seems to start fine unless coolant temp is still up near normal operating temp. I think #4 has something to do with this since if you keep cranking I can see a steady increase in it's ability to start on it's own like it's slowy increasing fuel until it starts.
And I am also suprised how easy full SD mode is to tune once you use VEMASTER to at least get them close to where you need them - I cant imagine initially manually writing (guessing) at all those cells.. wow
Good to hear about the high psi.. all i need is a pulley and fuel pressure.. and a little more tuning
Could someone check over my first crack at a 2 bar tune. It was done using dans tune as a base. And i would like someone to check it over before i change to a 2 bar map/tune etc...
stock lt1
5-9 psi of boost
meth
want to hold 14 degrees of timing in boost (used cant get wot timing below 26 deg for help)
added alot of extra fuel at 55 kpa and above to hopefully keep it safe the first time i hit boost, will lean out as necessary.
60# mototrons, injector constant set to 15 #
baro reset = 0 rpm
open loop
I have 1 o2 sensor in the downpipe right now wired to both banks of the pcm. Running on a 1 bar tune, two different o2 sensors keep reading lean for me. Tried running ve master on the 1 bar tune since i just recently switched to sd and the car starts reaking of fuel and drives worse then before. And the o2 still reads lean. I cannot detect any exhaust leaks. I would like to be able to use ve master to bring the drivability into check but i have been unsuccesful with the 1 bar tune so far. Any suggestions or should i just do this all open loop with a wideband and datamaster?
I can email to anyone who is willing to check it over for me. Thanks alot guys.
stock lt1
5-9 psi of boost
meth
baro reset = 0 rpm
open loop
stock lt1 <--- Does that mean stock cam too? Then you should 1/2 the stock file's MAP values and paste them in there or did you allready do that?5-9 psi of boost
meth
want to hold 14 degrees of timing in boost (used cant get wot timing below 26 deg for help) <---- WHAT DOES THAT MEAN?
added alot of extra fuel at 55 kpa and above to hopefully keep it safe the first time i hit boost, will lean out as necessary. I just creep up on it slowly.. I also added alot only to take it right back out..
60# mototrons, injector constant set to 15 # <---- If it starts then your good. If it doesnt start keep playing with this setting until it starts but make sure your not flooded cause then it will mask your good settings (might want to hold to floor once in awhile to see if it is flooded)
baro reset = 0 rpm
open loop
I have 1 o2 sensor in the downpipe right now wired to both banks of the pcm (yea I tried this with the WB02 in the left side header and the one bank that was under control made the other bank that was not in control go crazy.. well not really crazy but I did notice the BLMS were decreasing? to the point the SES light came on since the right side thought it was rich and kept pulling fuel.... people told me it wouldnt work for exactly this reason but I tried it anyway
Now moving it to after the Y may work I dont know
... . Running on a 1 bar tune, two different o2 sensors keep reading lean for me. Tried running ve master on the 1 bar tune since i just recently switched to sd and the car starts reaking of fuel and drives worse then before. <---- This may actually be because you only have one 02 in there and the PCM is adding fuel? In my setup it was pulling fuel so I dont know... And the o2 still reads lean. I cannot detect any exhaust leaks. I would like to be able to use ve master to bring the drivability into check but i have been unsuccesful with the 1 bar tune so far. Any suggestions or should i just do this all open loop with a wideband and datamaster? <--- YOu cant use VE Master unless you have two 02's hooked up for the reasons I posted earlier becuase the side with the 02 missing (or not in the correct side will be receiving false feedback) I have a whole post somewhere about the one 02.. pretty much I look like an idoit for trying it.. haha
One day I'll post results with one 02 after the Y... who knows...I can email to anyone who is willing to check it over for me. Thanks alot guys.
meth
baro reset = 0 rpm
open loop
One day I'll post results with one 02 after the Y... who knows...I can email to anyone who is willing to check it over for me. Thanks alot guys.Last edited by dookie454; Jul 8, 2008 at 10:27 PM.
Im trying to adapt the stock timing and ve tables over to a 2 bar tune and I just want to make sure I got things straightened out here. Im having some trouble setting up the 20-50kpa tables.
My car normally pulls about 36 kpa at idle. Is it safe to say that I can use the 30 or 35kpa column from the one bar tune as my 20 kpa column in the 2 bar tune?
Values in the 20kpa column “2 bar tune”= (Values in the 30-35 kpa column “1 bar tune”)/2
then
Values in the 25kpa column “2 bar tune”= (Values in the 50 kpa column “1 bar tune”)/2
Values in the 30kpa column “2 bar tune”= (Values in the 60 kpa column “1 bar tune”)/2
Etc etc etc
Am I correct?
Now if I understand this correctly you DO NOT divide by 2 when doing the timing? So it would be
Then
Etc etc etc
Then the 55-100 kpa “2 bar tune” is all the tuning done in boost
then
Etc etc etc
Am I correct?
Then
Etc etc etc
Baro Reset
Ok, Ive got my obd2 car running with the 2 bar map and only 5lbs boost and am already having some problems with the Baro reset issue. I'me tuning with Jet Dynamic Spectrum Tuner (only software I could find for my car at the time) and I have not found a way around this yet. Here are a couple questions.
1) Has anyone turned off the Baro Reset on an OBD2 program yet?
2) How can I get mine turned off when my software doesnt have the variable?
3) Could I send my tune to someone and have it turned off then I can just reload it in my software and tune this thing the rest of the way?
So far I really like the Way this 2 Bar setup is working but It's hard to nail this tune down when my datalog's will show the AFR at 12.9 on one pull with 53.86 Baro reading and then another pull with the exact same RPM and map and it will go 11.80 AFR with a 55.86 Baro......
1) Has anyone turned off the Baro Reset on an OBD2 program yet? Doubt it simply because this problem/feature was just discovered
2) How can I get mine turned off when my software doesnt have the variable? You cant unless you can talk one of the OBD2 companies/software into enableing the parameter in thier software and setting it for you then sending you the updated file.. Tunercat and LT1_Edit both offered up a modified file once I convinced them and they found and enabled the parameter.. I would think any tuning software company would appreciate this type of feedback and enable it for you at no cost
3) Could I send my tune to someone and have it turned off then I can just reload it in my software and tune this thing the rest of the way? Yes but you have to use that tune they sent back to you... because you cant see the parameter with your software just means it's there but it isnt looking at it, so if it's changed it will stay changed - this applies to Tunercat and LT1_Edit im not sure about other software
[QUOTE=cause4panic;5469734]Im trying to adapt the stock timing and ve tables over to a 2 bar tune and I just want to make sure I got things straightened out here. Im having some trouble setting up the 20-50kpa tables.
My car normally pulls about 36 kpa at idle. Is it safe to say that I can use the 30 or 35kpa column from the one bar tune as my 20 kpa column in the 2 bar tune? This should get you close but best thing to do is see where it idles on the 2 bar tune, compare that to the 1 bar tune, then use approximately 50-55kpa on the two bar tune compared to 100kpa on the 1 bar tune and make your divisions.. it'll be more accurate that way... simply halving them might get it close enough to start then you can use closed loop and VE master to get the rest.. just make sure you copy the 50+KPA from the non-vemaster file to the new 2bar file since VEMaster assumes/makes up numbers for increasing load even when it doesnt get values for them... if you dont copy the old 50+kpa values eventually it will be very rich under boost
I don't think TC supports the Jet OBD2 software anymore though.
yea.. can you tell I didnt know TC makes OBDII stuff? haha.
I just downloaded the new verson of DST (1.48) and it has the Baro reset in the Fuel Paramaters constant which I reset to 500 rpm. I'll test it later this weekend and see if it works!
Hey Guitarman what is DST? I've never heard of it. (I havent heard of much). If it says "BARO RESET" that is definetly it, you can double check but the stock setting should be 3600rpm, if it's not around 3600rpm it's probably allready been modified.
