1995 ECM Data Stream
Old Dec 30, 2010 | 03:36 PM
rangers458's Avatar
I have built a cable using a schematic I found, I think at aldlcables website, the two transistor, three resistor, and 1 diode. I have used this in the past and it worked.
I went to use this under Windows 7, and pccomm, freescan, and TTS Datamaster will not recognize the code being sent from the ECM.
Does anyone have a valid data stream so I can compare what I am receiving.
Under a terminal program I am getting steady data, using a prolific USB adapter that I have used in the past.
Also tried running all these programs under win XP mode in win 7 with no luck. The data stream appears to be constant.
Any help would be appreciated.
** Also, TTS Datamaster is stating that the ALDL connection is working, however receiving invalid Data. Using the 1995 F body profile.
Novo
Jun 14, 2016 02:58 AM
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
93 RedBird
Nov 15, 2015 08:24 AM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
