16 pin ALDL configuration
Hello, I have a problem. I bought a programming cable from WOT electronics, but when I wasn't using it the pins came off the OBDII connector. It is a OBDII to RS 232 cable for a 95 Z28. If anyone has this cable can they tell me what slot numbers the red, white, green and red wires go into on the 16 pin connector? Thanks for the help! You can see the pic of what i'm talking about here.
http://shbox.com/1/dlc1.jpg
http://shbox.com/1/1995_pcm1.jpg
The white wire on your WOT Electronics cable goes to pin 5, if that is what you mean.
ok, so I got all the pins back into the right spots. I could not get any program to work except for datamaster, and it only worked once, I could not get it to read again. It kept saying that it could not connect to the ALDL or PCM. I think it's a power issue. Anyone ever have this problem. Thanks
ok, I think I figured everything out. Thanks for everyone who helped. The pins are all in the right stops. My usb adapter is the wrong one and not allowing proper readings. Which adapter do you think I should get? The Belkin F5U103 or do the exchange program at AKM cables? Thanks for all the help everyone.
www.akmcables.com/trade-up.htm
