Z28 Cluster on Non-Z28
Old Mar 10, 2004 | 03:03 AM
JerZ's Avatar
Im looking to install a Z28 Cluster in my non-Z28 -- What is required to do this? Since the main differences are the Z28 has 130spedovs LT's 85.
Old Mar 10, 2004 | 08:00 AM
Erik's Avatar
Classic Tech Moderator
The speedo is a direct swap. I swapped out the 85mph speedo in my 80Z28 and everything worked as it should. Because I was a couple hundred kilometers from rolling over to 00000 on the odometer, I put my original odometer in the 'new' speedometer.
I would expect the entire cluster to be a direct swap.
If you have the whole thing out, you might want to look at installing a mechanical oil pressure guage where the (usually broken) clock goes. All you need to do is bend up a small metal bracket to secure the guage to.
mr28
Apr 20, 2016 05:44 PM
rwferguson43026
Feb 6, 2015 10:06 AM
Jan 5, 2015 07:14 PM
sdn1997rs
Dec 30, 2014 08:30 AM
Joes96z
Dec 13, 2014 07:48 PM
