yet another kid Q
Old Nov 6, 2005 | 05:59 PM
User56898's Avatar
yet another kid Q
i got a 67 camaro with a 327 in it and got one Q for all of u
should i be puttin in lead addivites to my gass?
if so, where can i get it
thx all
(10.5:1 compression)
Old Nov 6, 2005 | 06:00 PM
stale's Avatar
Re: yet another kid Q
thx all
Chances are that your 327 has been out at least once for a rebuild, and at that time, the valve seats were probably hardened. I wouldn't worry about it.
Old Nov 6, 2005 | 08:27 PM
User56898's Avatar
you think it will be better for it or not?
Will it hurt the motor any if i use it or dont use it???
Old Nov 11, 2005 | 02:28 PM
five7kid's Avatar
In my experience, the hardened exhaust valves & seats is not as common as you might think.
It's also not as critical as we've been lead to believe. It's most critical under sustained loading conditions, such as towing or hauling. I obtained a '71 GMC with a cabover camper in 1990 that needed a valve job. I ran it for 5 years after the valve job without any problems using an AMSOIL gas additive, didn't replace any valves or have any hardened seats installed. It was basically a poor valve job by GM back in 1971 that caused the problem.
So, I'd 2nd the part about it probably having had a valve job, which is the reason it'll probably be okay; and not because it probably already has the hardened stuff in it. Run it until it needs a valve job or you do some other upgrade that will make it convient to do the hardened valves/seats at the same time.
Old Nov 13, 2005 | 04:24 PM
bigblocktruck's Avatar
Its not going to hurt anything if you use it but will hurt if you need it and dont use it. You can get lead additives at any auto parts store.
Old Nov 13, 2005 | 09:25 PM
User56898's Avatar
i herd it raises the octane level....is this true?
Old Nov 16, 2005 | 10:54 PM
tfperf's Avatar
If the engine has never been apart, it should not be a problem since the years of using leaded fuel, when it was available, have coated the seats and valves long ago. If a valve job has been done and hard seats weren't installed, I would recommend a lead substitute or similar additive. I have seen exhaust valves sink in the head and destroy the seats in as little as 300 miles. The major determining factor, as stated above, is heat, load and rpm.
HAWG
Sep 25, 2015 11:41 AM
Rittmeister
Aug 7, 2015 01:13 AM
RougeZ28
Aug 1, 2015 10:41 AM
