Why is one headlight dim and the other bright?
Old Nov 18, 2005 | 12:06 AM
Lt1 and Ls1's Avatar
On my 67 camaro. The passenger side taillight is dim, I changed the headlight out, and it is still dim. The connection is fine. I mean it is real dim. Why is one headlight fine, and the other one dim? Bad ground maybe?
Old Nov 18, 2005 | 01:48 PM
stale's Avatar
Re: Why is one headlight dim and the other bright?
Same thing happened on mine. I just jiggled the wires and it was good to go. If that don't help, check the switch. Sometimes that old thing burns out and has to be replaced.
Old Nov 18, 2005 | 01:51 PM
Z28SORR's Avatar
Bad connection or bad ground. Check the wires.
Old Nov 19, 2005 | 12:51 PM
k9ulan's Avatar
sounds like a bad ground to me
Old Nov 19, 2005 | 05:40 PM
'86 350's Avatar
Well, I'll repeat it for the sake of repeating it, but it's 9 times out of 10 gonns be a bad ground.
Old Nov 19, 2005 | 05:58 PM
Thanks I will check it out. I hope that is all it is!
Old Nov 24, 2005 | 07:33 AM
Crovax WS-6's Avatar
i dunnno how well you maintain the car, but there might also be some corrosion on the connector causing increased resistance.
Old Nov 30, 2005 | 10:18 AM
Well I just bought the car not too long ago. Looks like she was sitting for a while
Old Dec 4, 2005 | 10:58 PM
coolram62's Avatar
I've had the same problem with my '73 CST.Loose pins inside the headlight wire connector was the problem.I used a small file to clean off the pins and gently spread them open for better contact.Then used dielectric grease to help keep out moisture.Also keep in mind you're dealing with a wiring harness almost 40 years old.You might consider using one of the headlight adaptor harness's availible from many places(Summit and JEGS sells them).What they do is take the load off you headlight switch,except to activate the supplied relays -headlights pick up power directly off the batery.Usually with a bad headlight switch both lights will be dim or not work at all.
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
95craz28
11
Sep 12, 2015 07:47 AM
jackpawt883
Sep 10, 2015 08:53 PM
