What's your 350-400 CID carb size?
Old May 20, 2003 | 08:03 PM
cadjock's Avatar
I'm trying to get a feel for what everybody else is using. Please state your engine size/max rpm/carb size and if you know, what's your ET and MPH.
Thanks!
Old May 20, 2003 | 08:30 PM
AJ1978TA's Avatar
406 Ci, 600 cfm, 5500 redline about.........A perfect example of what NOT to use....... If I hadn't wasted so much $ on this car, I would buy another carb, a 750 cfm Qjet, but I give up.
Old May 20, 2003 | 09:15 PM
talos's Avatar
640 speed demon
Old May 20, 2003 | 10:58 PM
Erik's Avatar
Classic Tech Moderator
Edelbrock 750
350
430hp
I probably won't start the thing for the first time until this weekend.
Old May 21, 2003 | 03:10 AM
Dirt Reynolds's Avatar
413" small block, 750 Holley vac. secondary. It's what you should be running on that 383.
Dave
Old May 21, 2003 | 03:12 AM
6spd69PowrSlyde's Avatar
406 CI
770 holley street avenger
BEST CARB I HAVE EVER WORKED WITH!
not only did this carb work great, but it fixed half the problems i was having! good idle, shuts off when key is turned (i used to have to pull the coil to turn it off-----YEOWCH! #*@U$!!!!!) and its real easy to tune.
i would suggest the street avenger for anyone.
Old May 21, 2003 | 11:28 AM
Duke79Zer's Avatar
I use a Holley 670 street avenger on a 355 325 hp this really is a great carb, and I just bolted it on and it was set really close out of the box.
Old May 21, 2003 | 06:29 PM
shocker45's Avatar
im runnin a holley 600 with #70 jets. instead of the #65 that it came with. it has vac secondaries
i got a 355 pushin about 375 hp flywheel
the 65 jets were too lean for me.
Old May 22, 2003 | 10:12 PM
406TA's Avatar
406sbc, RPM intake, XE274 cam, ported 2.02 double humps, Holley 750 vac. sec. carb (O-3310), redlines around 5500rpms. In a '79 Trans Am, 2400 stall, 3.42 posi. Fresh motor, so no ET yet. I ran a Holley 600 for a little while, and it ran well but it didn't feed her enough at higher RPM's.
Old May 26, 2003 | 10:31 AM
Damon's Avatar
I've been running 800CFM QJets on just about everything for the last 17 years or so. It's like the Swiss Army Knife of carburetors- not much it can't do. I'll put my QJet up against ANY vacuum secondary carb on the market.
Caveat: you have to know what you're doing with it as far as tuning and setup. NONE of them come out of the box performing like a champ. I don't recommend them for the first-timer. You can get all screwed up pretty quick trying to tune them like they are a Holley.
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
Jake Bialke
Sep 24, 2015 11:31 AM
colts0455
Sep 11, 2015 06:16 PM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
