What times to expect?
Old Oct 10, 2002 | 10:17 PM
BillyBigBalls's Avatar
i got the car in my sig.it weighs around 3300lbs.i got parts on order they are:
4 barrol q-jet
alminum intake
dynomax headers
2 1/4 true duals
turbo muffler
any idea what times i should get?i just wanna beat thoses lil civics
next paycheak im also planing on buying a 3.42 rear end.i got a 2.42 rear end in it now.what should i get with that rearend?
Old Oct 11, 2002 | 11:46 AM
HeavyChevySS's Avatar
You had another post about freshening up your 350. Is this the same car in question? If so, then read my other post and if you redo your 350 the way i said and you put that 3.42 rear axle in; I am guessing you'll be somewhere in the high 13's if you don't blow the launch. Good luck.
Heavy
Old Oct 13, 2002 | 12:05 AM
IrocSS85's Avatar
Re: What times to expect?
Im going to guess mid to high 14's. since theeng. isn s smog eng. and its worn out. plus the parts you are putting on are mild. Id sugg. a cam and stall conv. for your next mods if you wanna improve grtr times after that. prolly rearend gears too. have fun.
Old Oct 13, 2002 | 07:21 AM
CANTONRACER's Avatar
Mid 15's at best. Get a good baseline and go from there.
Old Oct 14, 2002 | 09:29 AM
5SPDCHK's Avatar
I'm going to guess mid 15's also. The 67 runs mid 15's with the just about the same set up...
CARiD
Jan 14, 2015 04:00 AM
cmdeshon
Jan 4, 2015 11:15 AM
redzed
Sep 4, 2002 06:22 PM
