what temp ???
Old Sep 9, 2005 | 04:53 PM
spinout's Avatar
what temp ???
what temp dose your car run at
my 327 with 9.6/1 compression
3 row rad and clutch fan seems to run
hot 200 or 210 on the highway
I am going to run a tranny cooler
for the 3500 stall im thinking that is where my
extra heat is comming from
Old Sep 10, 2005 | 09:48 AM
MaxHarvard's Avatar
Re: what temp ???
200-210 is a bit warm on the highway, i'd check your timing and coolant level, and check for air bubbles in the intake first.
i run 180 all day in traffic with a 11:1 350
Old Sep 10, 2005 | 10:32 AM
Dave89IROC's Avatar
Re: what temp ???
depenmds what temp tstat he is running, 200-210 would be right for a 190-195* tstat
Old Sep 11, 2005 | 03:35 PM
openroad's Avatar
Re: what temp ???
Is your fan shroud still intact?
Did you check to see if your clutch fan is still working properly?
Mine fluctuates between 175 ~ 190 from highway driving to traffic.
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
