What kind of heads are these??
Old Dec 27, 2005 | 02:42 PM
1st and goal's Avatar
I recently picked up a 73 Z/28 with the intention of yanking the motor out and putting either an LS-1 or LS-2 into it.
I'm going to drive the car this year with the 350 that came in it.
I was told the heads were Dart heads but I can't find any Dart markings on them. There is supposed to be a part number on the face of the drivers side head facing the front of the car but I can't see anything.
When I took off the valve covers the only markings I could see were:
Drivers side starting at#1 and going back to #7
I or 1 W then below were EBT
In the middle were CF in a circle
S/R
I-052
Pass side head
2-8
2 W
HF7
S/R
I-052
Any ideas?
It's been a while since I have worked on an old school sbc.
Thanks,
Marc
Old Dec 28, 2005 | 09:37 PM
curtg21's Avatar
Re: What kind of heads are these??
pics?
Old Dec 29, 2005 | 02:22 AM
5thgen69camaro's Avatar
If they are numbers matching set it aside, dont throw anything out. Thats my advice. Especialy if its a numbers match Z
Old Dec 29, 2005 | 09:48 AM
Curtg21,
My wife took the camera to her parents, will post some pics tomorrow when the camera comes home (oh yea and the wife and kid too)
The block is supposed to be numbers matching but I haven't looked for that either and I do intend to keep the block if it is numbers matching. Definatly a good idea
Brady thought they might be World heads, I've sent them a message and will see what they say.
They are iron heads.
Here's a link to some pics of the car (no motor pics)
http://www.ls1tech.com/forums/showthread.php?t=424309
Marc
Old Dec 29, 2005 | 08:03 PM
curtg21's Avatar
www.nastyz28.com should have alot of the numbers you need to verify the "numbers matching" parts.
Old Dec 30, 2005 | 12:34 PM
V8Rumble's Avatar
Also take a look at www.mortec.com/
Old Jan 9, 2006 | 05:17 AM
Dirt Reynolds's Avatar
Marc -- Robvas is correct, those heads are World S/R castings. As well as the obvious "S/R" cast into the head, "I-052" indicates the S/R head. If it was a 305 'Torquer' head for example, it would have '305' cast into the head instead of 'S/R'. The 'CF' in a circle is the foundry mark. World has used a few different foundries to cast their heads over the years. "EBT" and "HF7" are casting date codes.
Hope that helps you out.
Old Jan 9, 2006 | 06:27 AM
Marc
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
cmdeshon
Dec 27, 2014 10:06 AM
