What intake manifold for 12's ?
Old Jun 10, 2003 | 05:35 PM
zx1216's Avatar
Like i said what intake manifold would be good for a daily driven 79' camaro with a 350 in it. Would a victor jr. be alright to run on the street? I have the torqer II single plane right now and i will be getting a 750 speed demon carb. my goal will be to run in the 12's this summer.
Old Jun 10, 2003 | 08:50 PM
racr4jc's Avatar
I say ditch the torker and put a Performer RPM on it. The manifold alone is not what will get you into the 12s from the 14s, it is just part of the package. 12s don't require a radical package, just a good combination. The victor jr. is a good intake and you probably won't notice a huge difference when driving it, it just promotes more top end.
Old Jun 10, 2003 | 10:36 PM
Greed4Speed's Avatar
Actually, Car Craft (or one of those mags) did a test and the single plane made more low end torque on one engine combo. It all depends on the engine.
Personally, I prefer Weiand over Edelbrock. I ran the Team G for over 10 years on the street in a car that ran 12.90 in street trim. The Team G is less expensive than a Victor, and it comes w/ larger ports to begin w/ so you don't have to pay someone to port it for ya. Victor Jr. ports tend to be on the smallish side for porting purposes. This is why machine shops push them, more $$$.
That said, you don't have to have a single plane to run 12's. The Weiand Stealth or Performer RPM will work also.
Just get a manifold that is built for the RPM range of your cam. Cam choice , a good set of heads and a gear are more of what will get you into 12's than intake choice. If you drive an automatic, converter choice will go along with your cam choice.
Old Jun 11, 2003 | 12:04 AM
zx1216's Avatar
So would the cam i have now get me in the 12's with good cylinderheads?
Old Jun 11, 2003 | 01:26 PM
racr4jc's Avatar
Im not up on the hydraulic flat tappet stuff. I'd say your cam is big enough...what heads are you running?
Old Jun 11, 2003 | 07:06 PM
cadjock's Avatar
I'd say you are still not going to get 12's with any manifold. The performer rpm will help, and a victor jr will hurt. I think you'll need some decent heads and a little more cam to get you there. My combo got me there (barely) after a couple years of tuning and some sticky tires.
1979 Camaro
383
3.73:1
3200 stall
holley 600 DP
performer rpm intake
2 1/2" duals
234/244 cam .510 lift
Old Jun 11, 2003 | 10:00 PM
zx1216's Avatar
Yes i know the manifold alone won't get me into the 12's. I am not a moron. My question is what manifolds will support a 12 sec. car that can be daily driven.
Old Jun 11, 2003 | 11:49 PM
racr4jc's Avatar
The RPM, Vic Jr., Weiand Stealth... they all should be good for 12s. What your going to need now is a good set of heads. The Vortecs are prolly the least you will want. The Edelbrock E-tec 200s look pretty sweet. Supposedly they flow more than the GM Fast Burns and are cheaper. They're aluminum and have 2.02/1.60 valves which is pretty sweet too.
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
