thoughts on engine combo
Old Jun 15, 2007 | 04:11 PM
wifes86z's Avatar
I welcome your comments good and bad on the following
75 4 bolt high nickel block
bored .030
cast crank turned .010
block decked only for surface and to put pistons .005 in the hole
hyperutectic speed pro pistons
hastings rings
cam grind # 140120 @ .005 lift intake adv dur 292
exh adv dur 288
@ .050 intake lift 114 ATDC duration 224
exh lift 114 BTDC duration 224
degreed cam dead on 0
.045 quench distance
882 heads 3 angle valve job no porting
edel dual plain 1701? intake
1406 edel carb
HEI distrib
15 BTDC inital timing
AC R44ts gapped .060
maybe im expecting too much but doesnt run like i thought it would
I told the machinist i wanted longevity with a little punch but I guess I wanted more nuts. Do you think Im fighting the 700r4 and or rear gear or did I build a dog.
Your critisism welcome
Old Jun 17, 2007 | 11:30 AM
rhamm1320's Avatar
Looks pretty good with a nice torque curve. Future upgrades could include roller rockers, performer rpm intake, carb, ignition. Here is the computer dyno simulations.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
Alex Barnes
Jan 24, 2015 10:21 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
