small block numbers
Old Apr 27, 2005 | 06:37 PM
confused327's Avatar
small block numbers
im very happy with the identification of my carb but now i need to find the specifics of my two motors. ive narrowed them down to displacement but would like to know the exact year and number of main bolts if possible.
the #'s are as follows
350ci-v0717chc, 3970010
327ci-k0124fb, 3956618
im trying to decide which block to use for a '79 z28
Old Apr 27, 2005 | 08:27 PM
markinkc69z's Avatar
Re: small block numbers
Pull the pan?
Your 327 is from 68-69.
That block was also used for 302's and 350's.
The casting number won't specify whether its 2 or 4 bolt. The main caps are a machining operation. In other words a large journal 4" bore block could be machined for either.
400s are a different deal. You would generally look for a 2 bolt 400 block.
Your 350 block is the standard "010" casting found in virtually anything.
Either block would make a good foundation. Pick the best one that will clean up @ .030 and doesn't have an overheated looking main bore. The caps should fit tight. Also check the head bolt threads for integrity.
Old Apr 27, 2005 | 09:08 PM
Stephen 87 IROC's Avatar
v0717chc - 010 block
V = Flint engine plant
0717 = July 17
CHC was used on 3 different 350 blocks.
- 1975 L82 from a Corvette rated at 205 hp
- 1976 L82 from a Corvette rated at 210 hp
- 1980 used in full size cars
k0124fb - 618 block
K = St. Catherines, Ontario (Canadian built engine)
0124 = Jan 24
FB could be a 1955 265 (doubtful)
FB = 1969 327 rated at 235 hp with 2 bolt mains. Found in full size cars.
Personally I'd use the 010 block. Both are 4" bore blocks so it doesn't really matter which one you chose. The 010 block could be 2 or 4 bolt mains. You need to pull the pan to find out. Since it's from a car, I'd guess it's only a 2 bolt but if it was originally in a vette, it might be a 4 bolt. If it was from a pickup truck, there's a good chance it's a 4 bolt.
Old Apr 28, 2005 | 09:01 PM
thanks, i was hoping i didnt have to pull the pan but ohh well. i was having an argument about weather you could put vortec heads on a regular small block. i told my father that i think you can but you need a vortec style manifold, he thinks you cant. who is right? all help is greatly appreciated. oh yea about the 010 block i dont know what it came out of but is in a junky '78 camaro
Old Apr 28, 2005 | 09:36 PM
You're both right. Your way doesn't require machining. His way does.
Old Apr 28, 2005 | 09:57 PM
thanks, i found out they did shortly after posting but it sparked my interests, are the cast iron vortec heads say at jegs or summit the same as the ones found on mid '90's 5.7l engines.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
kennyirocz
3rd Gen / L98 Engine Tech
Feb 7, 2015 11:41 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
Collector Car
Dec 17, 2014 01:12 PM
