Recomend a STRONG tranny?
Old May 11, 2003 | 06:11 PM
ne1469's Avatar
I want to know what kinda of tranny I should use for a hot rodded 454.(keep in mind all this is currently in a dream process) I am looking for an aluminum 4/5 speed tranny that can take up to 800ish HP but will probly be using 650/700hp til I complete the dream.
oh btw I plan on this being a street car to go on road trips and cruise with.
edit: Any of you rodders know a good site for old muscle cars with a message board as active as this?
thx
Old May 11, 2003 | 06:50 PM
Capn Pete's Avatar
Lightbulb
If you want a tranny that will take that kind of power, but still be "driveable" (for road trips, etc.) you're going to have to spend some money. I'd say a well built TH400 with a Gear Vendor's over-drive unit would be the best?! I'm not too sure what other companies build racing trannies that offer overdrive? but that's probably what I'd do.
Old May 11, 2003 | 07:38 PM
Dirt Reynolds's Avatar
I second the TH400. They are strong as dirt and fairly cheap to build.
Old May 11, 2003 | 11:24 PM
CoryM's Avatar
Lenco. Or if youre feeling REALLY spendy, go for a sequintial 6spd from a road racer. Lencos start at what? $5000? Sequintials start at around $10,000 i think. A good 5 speed is the tremec 3550 but they are only rated to 540ft/lbs. It will take 1000hp for a while though.
CoryM
Old May 12, 2003 | 11:44 AM
jy211's Avatar
Th400. I had one bolted up to a 454, 550hp motor. no problem.
Old May 12, 2003 | 03:19 PM
Str0ked_69's Avatar
Sorry to impose on your thread, but i was just wondering. Will my precious muncie 4 speed will hold up to the 500+HP 396 i am building?I already have a built 700r4 and th400, but those im wanting to throw in two other camaro projects i have.
Old May 13, 2003 | 04:52 PM
Fickle's Avatar
That M4 is going to hurt. Of course, it always depends on your driving style. Is the car going to run on slicks and make frequent track visits? If yes, then you might want to build another TH400...
Old May 13, 2003 | 04:54 PM
Fickle's Avatar
TH400 all day.
Old May 16, 2003 | 01:22 AM
ATMINF's Avatar
A tremec T-56 from D&D that are upgraded to Viper specs are supposed to be pretty strong. They also are setup so they can be setup for a four speed bellhousing and don't need all the stuff from a "parts car". I think Car craft or Chey high per or one of the mags did a article on it about two months ago. In any case for a manual it all together will run about 4 grand to slap it to the motor and have it read to roll. In any case give them a call, and good luck.
Old May 16, 2003 | 01:19 PM
ForbesSS's Avatar
I went through a similar decision process. I'm only looking running a real healthy small block. It is just much cheaper to build an auto to handle a ton of torque. I'm going with a switch pitch TH400. Stall is 4000/1200. Hopefully add a GV when I hit the lottery.
Old May 16, 2003 | 04:55 PM
Steve72rs's Avatar
Go with TH400 (bomb proof)!, and try www.nastyz28.com awesome message board!
Old May 22, 2003 | 03:33 PM
ne1469's Avatar
Thanks.
I think I remember someone having a few th400's for sale but they needed to be rebuilt(I dont remember how much he was asking..). how much should I be expected to pay for one that needs to be rebuilt? How much would it cost to have it rebuilt?
and What the 700-r4's about?
thanks
Old May 31, 2003 | 02:37 PM
MSM69Z28's Avatar
you didn't mention if you preferred auto or manual. based on 4/5 speed, i am assuming a manual. i am currently running an M22 behind my 700HP procharged 69Z, but it isn't going to make it long. tremec's are ok, but wont hold to the power levels we are running. honestly, i will probably invest in a Jerico 4 speed or maybe a G-Force 4 or 5 speed. These can be purchased used for about 2k and new for about 3k , but they are rated for 1000-1200Hp of punishment. they were used in NMRA and pro cars, but they make a standard H pattern shifter version that is clutch assisted (as opposed to a clutchless shifting manual they also offer for drag racing). they are extremely durable. probably my choice when this one lets go.
later,
mike
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Ks0209
Oct 1, 2015 07:32 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
