rear of camaro
Old Feb 17, 2004 | 11:17 AM
CamaroSSgirl's Avatar
Exclamation rear of camaro
hi
On the bottom of the rear of my camaro '68 conv (where the license-plate should be) there is a hole, whats the meaning of this?
Old Feb 17, 2004 | 11:49 AM
Black Box's Avatar
Directly below the middle of the rear bumper? A friend of mine has a '68 and there's nothing back there, from what I remember. I don't know if it serves a purpose at all. As far as I knew, all of the fuel filler caps on '68's were all located on the rear panel above the bumper.
Belguim huh? I had an cousin who lived in Brussels a while back....what an beautiful place.
Old Feb 17, 2004 | 12:00 PM
FiefSS's Avatar
all 68's to the best of my knowlege had the gas filler above the bumper in the center. The hole where the license plate goes was on all of them as well but I have no clue as to what its purpose was.. if no one knows where try camaros.org since it goes pretty indepth in stuff like that. good luck
Old Feb 17, 2004 | 12:04 PM
Z28SORR's Avatar
Hard to say on something this old. Can you tell if it's drilled or stamped, i.e. OEM or not. Could be for additional lighting for the Euro. plates or for trailer hitch wires??
Old Feb 17, 2004 | 10:12 PM
StorminNorm's Avatar
From my experience - it serves no purpose.
Old Feb 17, 2004 | 11:24 PM
jg95z28's Avatar
Both the 67 and 68's have the hole and they do serve no purpose that I know of.
Old Feb 18, 2004 | 08:41 PM
kmanRS/SS's Avatar
hole
I have one in my 67and the only purpose i can find for it is to pull myself out from under the car
Old Feb 20, 2004 | 07:53 AM
scooters97ss's Avatar
Re: hole
Stuff like that is usually found more often on Fords.
Old Mar 24, 2004 | 08:46 PM
Black Box's Avatar
Existence of hole below the bumper is justified
Found out what this hole is for:
If you've ever dropped the fuel tank in your Camaro, this would help. When you re-install the tank, that hole is a good place to stick your hand through to get access to the rubber hose that connects the tank to the fuel filler neck.
Found this out today when a friend of mine put a new tank in his '68.
Hope this helps.
Old Mar 26, 2004 | 08:59 PM
Green95Z28's Avatar
You NEED that hole to drop your tank I've done it
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Collector Car
Dec 17, 2014 01:12 PM
CaRParts102
Dec 6, 2014 08:45 AM
Dec 4, 2014 11:56 AM
siguy
Nov 27, 2014 10:07 AM
