Ramjet 502 in a 68 Camaro
Old Jan 28, 2009 | 11:42 AM
ohsolow's Avatar
I was wondering if anyone knew if a Ramjet 502 will fit under a stock flat hood on a 1968 Camaro?
A customer of mine is trying to decide on an engine and want it to be fuel injected and fit under a flat hood. Since the car already has a big block he was kinda wanting to keep it that way so I can reuse all his accesories and headers.
Thanks,
Ian
Old Feb 11, 2009 | 08:41 PM
CamaroRS_SS
Guest
Posts: n/a
Originally Posted by ohsolow
I was wondering if anyone knew if a Ramjet 502 will fit under a stock flat hood on a 1968 Camaro? I am trying to decide on an engine and want it to be fuel injected and fit under a flat hood.
If this is the set up you are talking about
I don't think that you would be able to get that under a stock hood without cutting a hole in it. I don't know for sure as I don't have the measurements handy, but it appears much taller than a typical stock intake carb set up.
Old Feb 12, 2009 | 07:05 AM
ohsolow's Avatar
Thats the setup I figured someone on here may have put one of these in a 67-69 F-body and would know. I am going to try and get the measurements for the intake and see what kind of room I am going to have. I can always get a small cowl hood for it.
Old Mar 10, 2009 | 09:58 PM
User56898's Avatar
its been done. try camaros.net
Old Mar 13, 2009 | 02:41 PM
ohsolow's Avatar
Thanks, I will check that out. I measured it and it is tight. It could fit with trimming the braces a little bit. Probably just gonna put a small factory type cowl hood on it. The motor should be here anytime. Its coming from Jegs. They sell it cheaper than the local dealerships can even buy it for.
Old Apr 9, 2009 | 12:13 PM
KevinK's Avatar
Disciple
...if Camaros.net doesn't have the answer, ...you may also want to check out Pro-touring.com
Old Apr 13, 2009 | 04:06 PM
ohsolow's Avatar
I have come to find out that the car is an original Baldwin-motion and that somewhere down the line its been crashed and had a stock type hood put on it. I am going to buy the Baldwin-motion Hood and it should clear without a problem.
Old Apr 13, 2009 | 04:11 PM
ohsolow's Avatar
I got the motor last week ended up with the 502 Ramjet. Also the new heidts front subframe arrived today which was immediately sent out for powdercoating. I plan on starting next week puting this thing together.
Thanks everyone for your info.
Old Apr 14, 2009 | 04:45 PM
Rice Killer87's Avatar
Dude thats awesome !
Congrats on a nice find!!
Old Apr 23, 2009 | 10:07 PM
Z28Freak86's Avatar
U should post some pics when its done. That'd be nice to see!
Old Apr 25, 2009 | 10:56 AM
ohsolow's Avatar
I will post up some pics once I get started. The frame made it back from powdercoating. Still waiting on a flywheel before I pull the engine out of the crate. Once I get all the parts here I can start the assembly it should go pretty quick. It looks like we are also going to order up the new BMR torque arm conversion for the car also. I will post pics as soon as I can get some.
Old May 22, 2009 | 11:33 PM
sifa123's Avatar
Old Jun 11, 2009 | 06:55 AM
ohsolow's Avatar
It won't fit under a stock hood without lowering the engine. I have a SS hood and it is gonna be close. I will at least have to cut some of the inner bracing.
Old Jan 8, 2010 | 01:31 PM
jrutland's Avatar
I know this is old but do you have any pictures of the finished product? I bought a 69 Camaro with this motor in a few months ago and it's a blast.
Jerry
Old Jan 18, 2010 | 06:14 AM
ohsolow's Avatar
The customer kinda ran into a few issues so it still isn't finished. The engine is sitting in it and that is about the extent of it. The way things are looking it will be another month or so before we get the go ahead to finish it.
