Project car
Old Nov 4, 2008 | 05:41 PM
revolution79z28's Avatar
Project car
I'm fixing to start a build up with a '93 Camaro platform. The car has no motor or trans. I'm wanting to create a street/strip car. Should I go back with an LT1 or upgrade to a LS1 or LS6, or should I go with a carb motor? What trans should I go with? Auto or Manual? Gears? The car will have a roll cage in it. Fuel cell will be replacing the gas tank under the car. Any Ideas will be helpful. Build up will take about 6 to 7 years due to finacial status. Thanks.
Old Nov 17, 2008 | 02:28 PM
Rice Killer87's Avatar
Carbed motor no doubt, for $$$ reasons.
Use an automatic,Th400 or powerglide.....depending on combo
Gears will be determined AFTER engine combination has been established as well as converter stall.
Good luck and have fun!
Old Feb 25, 2009 | 02:07 PM
ayers1967's Avatar
Here's what I did with my old 94 z28. I left the fuel tank alone and wired a relay to run the fuel pump.Added a inline regulator to lower fuel pressure .Installed a 400 with a 700r trans with vacuum module to control overdrive. Reused the electric fans and cooling system.Added block hugger headers . Warning the distributor is and major pain to get to .
Old Mar 2, 2009 | 08:38 PM
doc221978's Avatar
On a budget a carbed sbc and a 700r4. If money isn't that much of a concern then a supercharged ls1 and 4L80e with a lock-up convertor.
It all depends on what you want to spend and what you prefer. Where I'm at I can get an LT1 with trans for $1k. If you look you may even find it cheaper.
Noenav
Mar 1, 2019 07:38 AM
ChrisFrez
Dec 28, 2014 02:25 PM
ChrisFrez
Dec 21, 2014 09:47 PM
cmdeshon
Dec 12, 2014 10:51 PM
USAirman93
Nov 24, 2014 03:37 PM
