Post your street/strip small-block combo
Hey Dave,
I see you have electric fans on your 77. What make are they and do they keep it cool? Im still running a flex fan in my 78. I think I can pick up a few hp with electric fans and a electric water pump.
Ray
Ray
Dirt:
If I had only known this I would not have bought my next setup and just bought 4340 5.565" rods. :/
Oh, and I believe somewhere I have the Car Craft w/604hp from Joe Sherman's setup!! We can get stuff like this from our library...I just "forgot" to give it back. hahaha
From: Teeter-tottering between Brilliance and Insanity
Originally posted by JEDCamino
Just retard the timing and get enough additional fuel. My friend is running 100 shot on a cast-piston 1965 Mustang I6.
Chevy High Performance got up to a 300 shot on a close-to-stock 350. In fact, the bottom end may have been stock, I can't remember.
The motor is uber fresh only about 100 miles on it with forged pistons and duramoly rings, so I think it will take th ebig shot at least for a while
Originally posted by BIGBADBOWTIE
Hey Dave,
Ray
Hey Dave,
Ray
Dave
Is a 350 w/400 crank and the short rods actually a 383??? Just curious. I would think it would drop the cui a bit.
As for my set ups. Here are the 2 good ones I had while I had a SBC (70 SS 350). I've joined the LS1 ranks now.
What it came with when I bought it 12 years ago and duplicated for a rebuild: 4 bolt .030 350 block. Comp cams 292 mag... .501 lift I/E don't remember anymore spec on it. Weiand Team G, Holley 750 mech 2ndaries, holley blue pump, 292 angle plug heads (ported) 2.055 I, 1.65 E valves, 1.5 rockers, forged flat top TRW pistons, stock crank and rods and a HEI w/ accel coil. Very well built th 350 w/valve body work instead of shift kit, 10" converter and 12 bolt w/ 4.11 gears. Idiot before me welded the spider gears together....
Not a bad car for a 19 year old.
Drove it daily and ran 12.90 right off the street shifting at 6000 RPM. The AC was still functional. Heads were a bit large for the cam or could have taken a larger cam, but I beat most things I raced. I later switched to a Mallory mechanical pump after I ate up 2 blue pumps. Didn't slow me down any either. Engine had more, but I wasn't very good at tuning.
2nd set up: Same components, different long block. Got a virgin bore 4 bolt 350 (scored it for $50 w/ stock pistons and rods, all machine work good) Ran the stock pistons and rods and a 305 crank. (Had to go cheap, married and both working our way through college at this time). Cam: Lunati Street master .507 lift I/E (don't remember lift @ .050) 108 * LSA and don't remember duration. Stock 186 68CC heads 1.94/ 1.50 valves. Low compression engine ran 13.36 on 87 octane. Not bad for a $800 long block. Loved the idle of this cam!!!
Last set up was done for efficiency and drivability and was based off the GM 330hp HO engine w/ a TCI sizzler converter, 3.08 posi w/ 4 wheel disk, 600 CFM Edelcrock POS on a Weiand Stealth intake, and same 186 heads. This was a high 14 sec slug. Took the fun out of driving the car.
Now I run mid 13's and get 30 mpg on the highway running 86 octane in my bone stock M6 00 SS .
Drove it daily and ran 12.90 right off the street shifting at 6000 RPM. The AC was still functional. Heads were a bit large for the cam or could have taken a larger cam, but I beat most things I raced. I later switched to a Mallory mechanical pump after I ate up 2 blue pumps. Didn't slow me down any either. Engine had more, but I wasn't very good at tuning.2nd set up: Same components, different long block. Got a virgin bore 4 bolt 350 (scored it for $50 w/ stock pistons and rods, all machine work good) Ran the stock pistons and rods and a 305 crank. (Had to go cheap, married and both working our way through college at this time). Cam: Lunati Street master .507 lift I/E (don't remember lift @ .050) 108 * LSA and don't remember duration. Stock 186 68CC heads 1.94/ 1.50 valves. Low compression engine ran 13.36 on 87 octane. Not bad for a $800 long block. Loved the idle of this cam!!!
displacement = pi * (bore / 2)2 * stroke * cylinders
So the correct formula is PI(~3.1416) X (BORE/2) X (BORE/2) X STROKE X Number of Cylinders.
Originally posted by jg95z28
Actually the volume of a cylinder (i.e. displacement) is PI * R ^2 (squared) * length.
lol. you arrive at the same answer I do.
Only if its a 4-inch bore you do. Did you mean for your formula to be (bore/2) squared, or (bore/2) times 2?
It's not the same if you meant the latter and the bore is anything other than 4.000 inches.
try 0.030 over....
(3.1416)*(4.030/2)*(4.030/2)*3.50*8= 357.157
(3.1416)*(4.030/2)*2*3.50*8= 354.498
NOT THE SAME ANSWER.
try 0.030 over....
try 0.030 over....
try 0.030 over....
btw, I didnt come up with the formula, some website on google had it.. so if you want you can argue with him over the internet all day.. THANKS! LOL
or you can use..
BORE X BORE X STROKE X .7854 X # CYLINDERS
yes, and the second formula in your example is mine.. everyone knows a 350 .030 over is a 355...the bottom is correct, the above is not. LOL
You simply CANNOT change math or physics to suit your fancy.
I threw that curve at you to test you. The standard stroke on a 350 is actually 3.48 inches NOT 3.5!
OOPS!
Try it again...
(3.1416)*(4.030/2)*(4.030/2)*3.48*8= 355.116
(3.1416)*(4.030/2)*2*3.48*8= 352.472 WRONG!
The formula for calculating displacement is based upon the volume of the cylinder.
The volume of a cylinder is calculated by taking the cross sectional area of the cylinder (a circle) and multiplying it by its length.
The area of a circle is PI * RADIUS ^ 2 or PI * R * R
The radius of a cylinder is 1/2 its bore hense the formula for calculating discplacement:
Displacement = PI * (BORE/2) * (BORE/2) * STROKE * Number of Cylinders.
Sorry but its basic geometry not magic. Your version works on a standard 4-inch bore only because 4/2*2 = 4/2*4/2.
Don't argue with an engineer when it comes to math. You'll lose every time.
1981 Z28
355ci. 11:1 compression
Dart Iron Eagles 215cc
Comp XE 284 .507/.510
Victor Jr, 750 D.P.
1 3/4" headers w/ 3" X-pipe and Spintech mufflers
CSI electric waterpump
Ramchargers dual electric fans
CE slapper bars, 90/10 shocks and Moroso Trick springs
8-point rollbar
8.5" 10 bolt with mini spool and 3.73 gears
Best time so far : 12.13 @ 109 w/ 1.65 60 ft.(n/a) 11.43 @ 116 w/ 1.58 60 ft. 150 shot
Short block Waitng to go in:
10.5:1 406
SRP forged pistons
5140 I-beam 6" rods(new)
8600N nitrated crank(new)
Comp Cams XE Solid roller .577/.583 248/254 duration @ .050
About the small base circle cam, I got mine straight from Competition Cams and it did not cost any extra.
Victor Jr, 750 D.P.
8-point rollbar
10.5:1 406
SRP forged pistons
OH my daily driver,
1981 Z28
355ci 9.5:1
TRW L2256 forged pistons
Eagle SIR 5.7 rods
Eagle cast/steel crank
Dart Iron Eagle 200cc
Crane 272 HMV cam .454/.480
Performer RPM
750 VAC. SEC.
TH350 w/ B&M 3000 holeshot
3.42 gears
12.97 @ 103
We were expecting this car to run in the 13.8-14.2 range
1981 Z28
355ci 9.5:1
Eagle SIR 5.7 rods
Performer RPM
750 VAC. SEC.
3.42 gears
12.97 @ 103
