Port and Polish
Old Jul 29, 2006 | 10:37 PM
propaintball96's Avatar
Port and Polish
Hi, im new the forum, i just bought a old 350 small block engien and im rebuilding the whole thing
I was wondering was the normal price to get your heads ported and polished would be?
Also, how big of a horse power gain would i get if i got the port and polish done?
Thanks!
Old Jul 30, 2006 | 01:19 PM
angel71rs's Avatar
Re: Port and Polish
Welcome to the board. Prices vary a lot by area and what you want done. By the time you consider what it will cost to get the heads rebuilt, plus the cost of the port work, a lot of times you are better off getting some new low buck heads. And with the newer heads you get a modern combustion chamber that makes more power and has better resistance to preignition.
Vortecs are popular, but they require a specific intake. But if you have to buy an intake anyway... Lots of good Vortec info here: http://www.nastyz28.com/forum/showthread.php?t=56505
Vortecs are 64 CCs, if you need larger chambers, there are iron heads w/72CCs available for under 750.
Old Jul 30, 2006 | 04:35 PM
jerminator96's Avatar
Re: Port and Polish
Just go get a set of Dart Iron Eagles. They are not real expensive and they come in a variety of sizes, per your specific application.
Just a thought,
Jeremy
Old Aug 1, 2006 | 09:46 PM
Re: Port and Polish
ill take that into consideration! thanks for the info!
i dont really have the money to buy brand new heads, is the port and polish really worth it?
thanks
Old Aug 2, 2006 | 12:33 PM
Z28SORR's Avatar
Re: Port and Polish
In this case the short answer is probably NO. But there are a lot of things to consider before you can deside. The most basic are what are you goals? Which heads do you have? What other performance upgrades are you going to do.
Saying you have a 350 that your rebuilding doesn't give us much information. Are you leaving it stock, or are you going for greater HP. How much? What's it going in? The more detail you supply the better an answer you'll get.
Old Aug 2, 2006 | 02:22 PM
IHI's Avatar
IHI
Re: Port and Polish
FWIW and to itinerate what's being said about the having your heads ported: in my area a really quick touch up starts at $500 with a full blown job easily hovering around the $1500 mark for having a shop do the work. Biggest reason guys take heads in is to increase air flow, but when you see true to life pricing when hiring it out it's a no brainer to typically use that money and just buy new heads with increased flow..ie larger heads.
G-BODYT56
Jan 14, 2022 11:14 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
