Oxygen Manifold
Old Apr 5, 2005 | 11:21 AM
rwjohnson06's Avatar
Oxygen Manifold
I am thinking of how hard it would be to install headers on my 1980 camaro without having the oxygen manifold visible from the top of the engine. Is it possible to relocate the oxygen line to the bottom of the engine or at the end of a long tube header. Ive seen on a newer model (97) vortec 7.4 where the oxygen ports are ported at the 1st cylinder on the top of each manifold only, i was thinking of doing that, but the engine would look even better with it not visible at all. I would like to totally eliminate the Oxygen system. but in this case i live in california and have to keep the car smogged.
Old Apr 5, 2005 | 03:26 PM
MaxHarvard's Avatar
Re: Oxygen Manifold
What the hell is an oxygen manifold?
Old Apr 5, 2005 | 10:15 PM
camcojb's Avatar
Re: Oxygen Manifold
I believe he's speaking about the smog pump and the lines that go into the exhaust manifolds/headers.
Jody
Old Apr 5, 2005 | 10:41 PM
Re: Oxygen Manifold
[QUOTE=camcojb]I believe he's speaking about the smog pump and the lines that go into the exhaust manifolds/headers.
Jody[/QU
Yeah that is what im talking about. I apologize. Thats just what my 2nd gen camaro owners manual names the part.
Old Apr 6, 2005 | 07:43 AM
MaxHarvard's Avatar
Re: Oxygen Manifold
Jody
hahaha, oh good god, thanks Jody... i havent dealt with smog stuff in soooo long i forgot they even existed
Old Apr 6, 2005 | 09:01 AM
camcojb's Avatar
Re: Oxygen Manifold
No problem Eric! Back to the question, I would say it would still work as long as the line is hooked anywhere into the exhaust manifold, top or bottom. If you drop to one line it will need to be larger than if you use the individual lines the 80 Camaro had.
The problem though is that California may not pass it if it doesn't remain the way the factory set it up.
Jody
Old Apr 6, 2005 | 06:41 PM
Re: Oxygen Manifold
Jody
Ok thanks. Now what about headers? Could i do a single port o2 injection running the lines into the headers near the 3bolt flange?
GREEN3112
Feb 10, 2019 09:19 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Pwilson59
Sep 3, 2015 08:47 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
ShiftyCapone
Aug 27, 2015 10:14 AM
