Need help with suspension on 74 camaro LT
Old Aug 4, 2002 | 08:39 PM
woodrell's Avatar
Post Need help with suspension on 74 camaro LT
What is a good lowered spring/shock combo for a 74 camaro LT? 350 engine w/headers, no a/c, currently have rear air shocks w/ full air but not sure if some adjustable rear shock would be a better choice (I like the jack up rear end look), 225/60/14 tires on front and 255/60/15 tires on rear (if that matters).
Weekend driver, occasional track.
I've seen 1", 1-1/2", and 2" drop springs in online catalogs.
I like the lowered front look but not to where I bottom out on every bump in the road. (I do now because I was talked into "cutting a coil off my stock front springs") Now I want to do it right.
I'm thinking I want an 1-1/2" drop springs and appropriate shocks.
Eibach, Global west, Doestch etc?
Thanks for any help.
Brian
[This message has been edited by woodrell (edited August 04, 2002).]
Old Aug 5, 2002 | 09:26 AM
Bill B.'s Avatar
Post
Hey Brian!
You might want to check out the website below. I spend almost as much time there as I do here. Anyway, there are several 2nd Gen owners there, and they are all into lowering for the purpose of handling. You can go to the "Cars" section and find out what mods some of them are using. Or you can go to the "Forum" and read or post any questions. Check it out:
www.pro-touring.com
Hope that helps!
Bill B.
'69 Camaro SS396 with '81 305:
stock except for Performer intake, 600 Holley vacuum (modded), Perf. Dist. HEI, 1-5/8" headers & 2-1/2" exhaust/turbo mufflers,
beefed TH 400 tranny with 11" street convertor & B&M Quicksilver
3.08 posi 12-bolt
P235/45/17 and P275/40/17 Kuhmos on 8x17 Wheel Vintiques rallys
H.O. Racing front coils, Flex-a-Form fiberglass leafs, Herb Adams VSE body bushings and frt. sway bar, '79 T/A P/S box, power disc front brakes w/metallic pads
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Collector Car
Jan 5, 2015 10:58 AM
NewsBot
Nov 25, 2014 11:20 AM
