Lt-1 into a 70 Camaro?
Old Feb 3, 2004 | 05:15 PM
  #16
JDBlazer454's Avatar
Thanks a bunch for that info
We talked to our tranny guy and he strongly recommended us going with the 4l60e also for the same reasons you said. He said we will be able to use our stock tranny crossmember just needs to be moved back a little bit and new holes drilled.
As for the radiator I am going to reuse the 94's radiator as my new one is leaking like my other one was. Just going to have a radiator shop test it for me and fix any problems it may have. Also using the 94's dual electric fans, they are so nice, then the comp will be able to control them correctly.
I am going tonight to look for a book that Car Craft recommended, been reading myself silly lately. We hope to have it in and driveable by September for our area's biggest cruise, at least thats the current goal. At the moment we are still in the strip down phase of the donor car.
Old Feb 3, 2004 | 06:09 PM
  #17
Piet's Avatar
What book would that be?
Old Feb 4, 2004 | 01:25 PM
  #18
Efi basics and Lt1 to street rod conversions, I think they both said by HP books or something similar. Figured wouldn't hurt to have a book handy.
Old Feb 5, 2004 | 01:14 PM
  #19
Piet sent you an email with the EFI swappers guide attatched, Enjoy!!!!
Old Feb 5, 2004 | 02:55 PM
  #20
Piet's Avatar
Got it!
Great Info! ULTM8Z rocks
Old Feb 5, 2004 | 03:02 PM
  #21
Incredible reading isn't it. He did such a great job
Old Feb 6, 2004 | 03:06 AM
  #22
Teetoe_Jones's Avatar
Arrow Just a little FYI
I did this swap about 4 years ago in my 68 camaro with a t56 six speed. Just for the record, LT1 engines are reverse flow cooling, meaing the coolant travels to the heads first, and block second. You can use any radiator you want, it does not have to be from a LT1 car.
Tyler
Old Feb 6, 2004 | 09:46 AM
  #23
Jeff H's Avatar
I recently bought a 68 Camaro with a 94 LT1/4L60E in it. It wasn't a finished project, but it was running. I researched the radiator thing a lot and if you look at the 84-89 Corvette radiator, it has the smaller hose inlet and outlet so it should work well with the LT1. It's a little wide for the 1st gen cars, but might fit fine in the 2nd gen. There's a guy offering the wiring conversion on Ebay so you could use the 94 harness and have it modified for under $300. I just had some Hooker headers with O2 sensor bungs installed and coated so I can run the O2 sensors. And there is a product called the Cable-X which takes the electronic signal from the transmission and runs an electric motor to turn a speedometer cable so you can run your original mechanical speedometer. It's around $270.
Old Feb 7, 2004 | 01:16 PM
  #24
96LT14u2Nv's Avatar
i am currently doing the same thing in my 64 chevelle but i am still in the engine building part of it so i cant be of much help to you, but just wanted to give u two big thumbs up for this project.
Old Feb 7, 2004 | 02:37 PM
  #25
Thanks for that, same goes to you into a 64 Chevelle (one of my favorite years btw ). I feel pretty confident this will be a straight forward and easy conversion. I have done so much research and educated myself and found it is the common swap to do right now and there are a few pioneers that have done it. The engine is coming out of the 94 today and the prep work starts on the Lt1 and the 70. We figure plug away at it weekend to weekend and we will reach our goal. Our goal to have it road worthy is 8/29 (our Camaro clubs All Camaro show) wish us luck
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
cmdeshon
Jan 4, 2015 11:15 AM
sskevinm
Dec 18, 2014 11:16 AM
