How to tell if it is a real 1967 SS
Old 01-08-2008, 11:10 AM
95z115's Avatar
I was wondering how I find out if this car I am looking to buy is a real SS. Any help or input would be great! Thanks guys
Here is the information on the plaque....
VIN# 124377L113417
11A A486
ST 67-12637 LOS 4594 A-A
TR765-2
W 2EMG 3K
Body By Fisher
95z115 is offline
Old 01-08-2008, 03:13 PM
Z28SORR's Avatar
Bottom line on this is, there is no way of telling, everything can be faked.
What you should be looking at is the sellers provenance. In other words does he have original documentation proving this is a real original SS.
P.S. Even the documentation can be faked. Several people were scammed at a resent Barret/Jackson aution. But at least with the correct car and the documentation you have a chance.
Z28SORR is offline
Old 01-08-2008, 09:22 PM
mrmint69's Avatar
You can sometimes find options that are only on the SS and check to see if they are there. If they look original that a big plus.
mrmint69 is offline
Old 01-09-2008, 09:51 AM
95z115's Avatar
Which options were ONLY available on the SS? I think possibly the hide away headlights?
95z115 is offline
Old 01-09-2008, 11:32 AM
Z28SORR's Avatar
Don't know about 67, but in 69 the "hide away headlights", were an RS option not an SS option.
Z28SORR is offline
Old 01-09-2008, 06:58 PM
User56898's Avatar
same for 67' but you could get a RS/SS and have hideaways on an SS
mine is a SS clone, all the badgeing....everything eles is aftermarket.....
i would actually be a little upset if mine was a real SS due to the fact the only thing still from 1967 is the subframes and body (most of the body)
there are tricks. Ask the guys at Camaros.net.....they know their shyt when it comes to 1st gen
if i remember right there is the vin the door jam and the tag in the engine bay that should say if it's an SS. Think it should be rivited on or possibly two tack welds. Easy to fake though....
User56898 is offline
Old 01-09-2008, 10:03 PM
firebird69racer's Avatar
from what I see
Vin # 124377L
4= V-8
7= 1967
L= Van Nuys,Ca
some of the trim tag #'s dont make since, but this is what I can make out
11A= Nov. 1st week
ST-67= 1967
12637=Sport Coupe Custom Interior
LOS= Van Nuys,Ca.
TR765-2(I belive 2 should be Z)=Black Interior, Bucket Seats
A-A=Black Ext. Paint
W= Tinted Windsheld
2EMG= A/C,TH-400,Center Console
3K= RPO Z21 (style trim group)
For more info check out this site
http://www.chevy-camaro.com/chevy-ca...ecode-1967.asp
firebird69racer is offline
Old 01-13-2008, 01:51 AM
mitchleftwich's Avatar
build sheet
look for ther build sheet under the rear seat. sometime I get lucky and its still there.
mitchleftwich is offline
Old 01-15-2008, 10:12 AM
AlwaysCode390's Avatar
RS = hideaway lights ... my car is number 60k from Van Nuys ... its like they are brothers ---
AlwaysCode390 is offline
Old 01-15-2008, 03:06 PM
jg95z28's Avatar
1 = Chevrolet
2 = Camaro
4 = 8-cylinder engine
37 = coupe body
7 = 1967 model year
L = Los Angeles, CA assembly plant (Van Nuys)
113417 = vehicle serial number sequence
Decode for body number: 004594
11A = Built the First week of November.
67-12637 = Custom Interior Coupe.
LOS = Built in Van Nuys California.
765 = Custom Black Bucket Seats.
Z = (A50) Strato Bucket Seats (without headrests).
A-A = Car Color is Tuxedo Black
A486 = internal plant scheduling code.
Options:
1W = (A02) Tinted W/S only
2E = (C60) Air Conditioner
2M = (M35) Powerglide Transmission
2G = (D55) Console front compartment
3K = (Z21) Deluxe exterior trim
While most SS-350s should have a 4P code as well, as an early build car it is still possible that it did not get the 4P code. (Assuming it is a 350, does it have the original block? If so, what's the engine code?)
2M is definitely a Powerglide. Its far too early to be a TH400 any way.
http://www.camaros.org is the best source for 1st gen information.
jg95z28 is offline
Old 01-20-2008, 08:54 PM
Thats funny, a friend of mine has a couple of 67's with a TH-400
Did you read this from the site you posted
"At the LOS factory, the 2M code was applied to any automatic transmission, including the M40 (e.g., the 2Z code was not used). At the NOR factory, this code was only applied to M35 transmissions that were in combination with the D55 console."
And it should have the 4P code if it was built in Nov. and had a 350
From your site
"The 4P code was not used at the start of production at either the Van Nuys plant or the Norwood plant. Van Nuys started using the 4P code on the SS350 cars in September, but Norwood didn't start using the 4P code until October. Early Van Nuys SS350 cars and Norwood SS350 cars built before October will not have the 4P code to verify that they are SS's."
And it says the same thing on the site I posted
For the 2M code it says (LOS - TH400 it is thought), and Z - TH400 3-speed Automatic (NOR only it is thought).
They put TH-400 in 67 and up Camaros
Just curious why it would be to early to be a TH-400
This is from the site I posted
"Location K - Option Information (2)
B - three-speed on floor
E - air conditioning
G - center console
H - heater delete
L - four-speed manual transmission
M - Powerglide transmission (LOS - TH400 it is thought)
R - rear seat speaker
S - rear antenna
U - eight-track/multiplex
Note: "2" appears as a trim tag location identifier on Camaros with one of the above options but is not an option code itself."
Old 01-20-2008, 09:30 PM
jg95z28's Avatar
The TH-400 was a late model year addition. The car in question is a November (1966) built car. I also have a November (1966) Van Nuys built Camaro, it is also a 2M code, and it also has a powerglide. Furthermore TH-400 was only available with a 396 in 1967. This car is definitely not a 396.
jg95z28 is offline
Old 01-22-2008, 10:43 AM
jg95z28's Avatar
FWIW, the site you posted is less than accurate on a lot of things. http://www.camaros.org is the most accurate source for first gens Camaros out there.
jg95z28 is offline
Old 10-02-2018, 01:08 AM
Fergdog's Avatar
Re: How to tell if it is a real 1967 SS
Can you please help decode my car?
67 Camaro, I think it is an RS but has an ss hood Any help deciding is much appreciated, thank you!
Fergdog is offline
Old 10-02-2018, 01:14 AM
Fergdog's Avatar
Better picture
11A
67-1234 LOS 8141 B081Y
760-Z R-2 paint
E E2EM6R 3DL
5Y
Fergdog is offline
Quick Reply: How to tell if it is a real 1967 SS
