header question
Old Feb 23, 2004 | 06:47 PM
78sixbanger's Avatar
header question
ok, i have a 78 camaro that had a 4.1L in it, itsin the shop no gettin a new vortec 350 put in it. I need to get a setof headers for it. I wanna get hooker longtubes. The shop tht is doing the work says the headers have to be specifically for a vortec 350, does hooker make longtubes for it? if so does anyone have the part #. Thanks in advance
Old Feb 23, 2004 | 07:05 PM
JEDCamino's Avatar
I would think regular 350 headers would work. Unless the exhaust port is a different shape. I believe there are two different ports.
One shaped like this: 0
And another shaped more like this: []
I could easily be wrong, though.
Old Feb 23, 2004 | 07:56 PM
kacy's Avatar
lt1s have a D shaped port
Old Feb 23, 2004 | 09:40 PM
Erik's Avatar
Classic Tech Moderator
The vortek engines have angle plug heads, so you can't use regular classic sbc headers. Hedman makes an inexpensive set, which I have on my car (angle plug heads). I'm not happy with them though. They warped badly after cam break-in and I've had a hard time getting them to seal since. I'll replace mine with Hookers. :/
Don't put coated headers on an engine during break-in. The unusually high temperatures that sometimes occur during break-in can damage the coating.
Old Feb 23, 2004 | 09:54 PM
part no. for the hookers?
Old Feb 28, 2004 | 01:09 AM
extreme79z's Avatar
Funny you should ask this... I happened to ask the same questions last night. At Nastyz28.com Now I see I wasn't the only person confused about it. I had heard many of the things that were mentioned in this topic which are innaccurate (example- Vortec's are angle plug heads, you have to run Vortec headers)
I found out that the truth was that I could run any headers I wanted and that they were straight plug heads. If you want the whole topic drop me an email and I'll let ya check out the whole thing.
Old Feb 28, 2004 | 01:39 AM
Zedzag's Avatar
The 330hp engine has the cast vortecs which are straight plug.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
