Exhaust Backfire
Old Nov 25, 2005 | 08:29 AM
crazymanz28's Avatar
Exhaust Backfire
Ok its been awhile since I have been on, but I have a 79' Z with a fresh 350. Anyways it is backfiring through the exaust at idle... Its not that bad but pretty consistant. Do I need to retard or advance the timing? Or could it be that its cold outside and I have no exhaust behind the full-lenght headers? I have checked my plugs, exhaust manifolds at the heads and internal drivetrain.
Old Nov 27, 2005 | 09:14 PM
stale's Avatar
Re: Exhaust Backfire
Could it just be the idle mix on your carburetor? If you're too lean, that exhaust charge'll ignite. What's you timing at now?
Old Nov 29, 2005 | 12:22 AM
TheNovaMan's Avatar
Double check your plug wires. I'm am extremely careful, patient guy, but I once had a couple plug wires switched around, and my engine backfired consistently.
Also, position the engine at TDC for the #1 cylinder and check the relationship of the cap and rotor. If you have a Holley or Edelbrock carb, make sure the idle mixture screws are out approximately 1.25 turns. I guess if all that doesn't help, check the fuel pressure and float level.
May 21, 2015 01:04 PM
May 15, 2015 10:43 AM
Chet1185
May 10, 2015 09:24 AM
Drtryder
Apr 22, 2015 04:17 PM
F(ast)-body
Feb 26, 2003 09:05 AM
