Decoding motor again...PLZ
Old Mar 18, 2006 | 03:14 PM
User56898's Avatar
The number on the driver side rear of the block is 8(could be 3, so hard to see)956618 (either 8956618 or 3956618)
The Number behind the alt. on the passanger side front is K08 0(could be 6) 60NU (K08060NU or K08660NU)
I was told that is was a 327 out of a vette, unknown what year. I had it bored to a 333 and built up from there.
Old Mar 18, 2006 | 07:24 PM
Stephen 87 IROC's Avatar
Re: Decoding motor again...PLZ
3956618 = 1968-1969 4" bore block
327 4 bolt A and F body and Vette
302 290hp 4 bolt Z28
327 235hp 2 bolt A body cars
350 250hp 2/4 bolt any body style
K08060NU
K = St. Catherines, Ontario
08 = August
06 = Day
ONU = Unknown suffix code. Recheck these as they will say if this is a real 327 vette engine or just another 4" bore block.
Old Mar 18, 2006 | 07:26 PM
CNU comes out to a 1970 350 engine that originally had a powerglide behind it. Rated at 250hp, 2 bolt and came in A body cars.
Possible but that casting wasn't supposed to be used in 1970.
Old Mar 18, 2006 | 07:36 PM
After doing a quick search through suffix codes, CNU looks like the best choice except the year doesn't match the casting number. I also don't see a suffix code for a 327 in a 68-69 vette.
Old Mar 18, 2006 | 09:34 PM
User56898's Avatar
thxs i will make sure i gave you the right numbers tomarrow.
thxs a lot for looking all that up. I couldn't find anything.
Old Mar 19, 2006 | 05:46 PM
User56898's Avatar
hey i got the numbers wrong! took me a while to clean it so i can read it. The number on the front is K08060NU
on the back it has a big GM then under that it has 3856618
to the right of that it has a BIG M in a box and the number 3 in a circle
Old Mar 19, 2006 | 06:06 PM
User56898's Avatar
omg i serched and serched and still cant find anything
Old Mar 19, 2006 | 06:23 PM
User56898's Avatar
the back casting number is 3956618
i now have a great pic if u want it
Old Mar 19, 2006 | 06:27 PM
User56898's Avatar
3956618 1969 302 290 4 Z-28 Camaro
3956618 1968-69 327 235 2 Passenger
3956618 1969 350 250-350 2/4 Passenger/Chevelle/Chevy II/Corvette/Camaro
Old Mar 19, 2006 | 08:16 PM
Casting number still only says that it's a 68-69 4" bore block. 302, 327 and 350 all use the same bore.
I still can't find the suffic code ONU. CNU would be a more common code since the majority of cars start with C and truck block start with T. There's a handful of other codes but there's only 2 suffix codes that start with O and they were in 1978. One for a 305 and the other for a 350 both in a Firebird.
Trying other posibilities, there are no CNx codes at all for a 327.
Since you've rebuilt it, it must have been a 327 or at least has a 327 crank in it but the block wasn't from a 68-69 vette.
Old Mar 19, 2006 | 08:24 PM
User56898's Avatar
there is no possiblity of it comeing from a later vette (69+)???
I am 95% sure it says K0806CNU and 3956618 (pic)
found of some site:
CNU 1970 350ci 250hp 2 Powerglide trans.
Old Mar 19, 2006 | 08:45 PM
jms's Avatar
jms
Could the numbers on the pad be #### "M" U where the # before the "M" is a zero?
If so, "MU" is a '67 and '68 Camaro 350 number OR "ML" which is a '67 Camaro 327 number, both of which should fit the casting number on the back.
My info (very old Chilton books from the early 1970s) also says CNU is a 1970 250-horse 350 (with powerglide) from a big Chevy.
jms
Old Mar 19, 2006 | 08:54 PM
User56898's Avatar
JMS i have no idea what you are trying to say....(i am bad at this)
pad is the number on front or rear (cast #)
u mean if the N was really a M?? Ill try again tomarrow (just got the car cover back on in garage....yes i am insane)
Old Mar 19, 2006 | 09:11 PM
Dave89IROC's Avatar
pad is the stamped number on the front, the casting number is on the rear
Old Mar 19, 2006 | 09:50 PM
User56898's Avatar
okay thxs
this motor is confusing....
