Converter for my tranny. What stall to aim for!?
As the title said: What size stall should i look for in my next converter for my set up?
The 67': 408ci small block stroker 510hp TH400 Trans 4:10 rear gears (possibly smaller when upgrade rear) 10.5 tires Mostly street, ocasional track Goal 11.4 sec 1/4 mile on motor, 10's with spray |
i'd say about a 3600.
What's the advertised duration of the camshaft?
Is that stroker motor based off a 350 or 400 block?
Originally Posted by rik89gta
(Post 5557632)
-10.5:1 compression
-cam Xez88HR-10 #08-433-8 -Dart Pro 1 heads -.520/.540 lift duration @ .006 I=288 E=294 @.050 I=236 E=242 510hp |
Sounds like the A-2 408 from T@L Engines. How's that motor working out for You? My A-1 408 made 505 hp and will be hear Monday.
288/294 duration. I'd suggest a stall speed around 3600-3800.
(Post 5569539)
Never ran it yet :( waiting for trans..... |
Yeah, They're a pretty busy shop but they shouldn't promise anything. I was told 6-8 weeks but it actually took almost 5 months. But I finally got my motor and it I hope it was worth the wait!
