chevy 305
Old Dec 15, 2003 | 05:39 PM
dnz28's Avatar
chevy 305
I was wonder if the chevy 305 is a chevy 350 with a smaller crank? And different heads? Cause I found a good deal on one for 100 bucks running
Old Dec 15, 2003 | 08:30 PM
angel71rs's Avatar
305 has same stroke as 350, but a smaller bore. Heads have smaller chambers (58-59cc common) than 350 heads (76 or 64cc). 305 is a decent engine for a grocery getter, and can be built to make good hp, but a 350 is a better starting point.
Old Dec 23, 2003 | 09:12 AM
jays76camaro's Avatar
My stock 305 in my 76 was rated 140@2800
I yanked that out immediately for a 350
Old Dec 27, 2003 | 01:01 AM
94m5's Avatar
In addition to that.....Many people try to put 305 heads on a bigger Smallblock to raise the compression. This WILL raise the compression But will reduce air flow due to smaller valves. Unless you NEED a running engine I would pass this deal up. The larger bore blocks are the way to go. Mike
Old Dec 27, 2003 | 10:27 AM
dnz28's Avatar
i have a working motor i just thought for a 100 bucks it wasnt a bad deal just tring to learn something about before i would purchase it. i didnt buy it though.
Old Jan 5, 2004 | 10:55 PM
FiberglassBlues's Avatar
Cool
Sure did sound cheap enough! But im like everyone else more cubes the better
Old Jan 5, 2004 | 11:34 PM
killer-camaro's Avatar
actually the 305 (i'm assuming you want the Z/28 engine) is a 283 block with a 327 crank. you could aslo accomplish this goal by finding a small journal 327 and putting in a 283 crank.
Old Jan 6, 2004 | 08:53 AM
BIGBADBOWTIE's Avatar
ACTUALLY......
the 305 is not a 283/327 combo..... the 305 has a 3.740 x 3.48.
The 302 which was the 67-69 z motor was the same bore as a 327.. (4.00) and stroke of a 283...(3.00)
Just wanted to add that.
Old Jan 6, 2004 | 12:02 PM
bowtie-70's Avatar
Thats the 307.
Old Jan 6, 2004 | 01:51 PM
nape's Avatar
Originally posted by bowtie-70
Thats the 307.
Wrong again.
307 was a 3.875" bore with a 3.25" stroke.
327 with a 283 crank is a 302.
Here's a page that lists SBC specs: http://www.dumpit.org/grimreaper/sbc-engspec.html
Old Jan 7, 2004 | 08:11 AM
bowtie-70's Avatar
307 = 283 bore & 327 stroke
302 = 327 bore & 283 stroke
305 = unique bore & 350 stroke (had the smallest bore & longest stroke)
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
May 16, 2015 04:20 PM
formula79
18
Jul 1, 2002 02:39 PM
