alternator pulley info help needed
Old Apr 19, 2011 | 11:18 PM
User56898's Avatar
I have an alternator that only charges the batt at around 2000rpm. At idle my volt gauge reads 12V and at 2000rpm it reads 14-14.4V.
It has a really big pulley, but if i change to a smaller pulley will it fix it so it charges at idle? Or will it just blow the alternator and i should replace it?
Old Apr 21, 2011 | 04:10 PM
User56898's Avatar
Re: alternator pulley info help needed
bump de de bump
Old Apr 22, 2011 | 09:51 AM
Z28SORR's Avatar
Alternators are not efficient at idle. Putting a large pulley on, will make it less efficient. Many hot rodders recommend that you Do Not put an underdrive pulley on the alt. for this reason.
Yes, replacing the over size pulley with a smaller one(stock) will help with your low rpm charging.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
CamaroZBoy
Aug 16, 2002 10:03 PM
mjcent922
Jul 27, 2002 12:42 PM
