alternator pulley info help needed
I have an alternator that only charges the batt at around 2000rpm. At idle my volt gauge reads 12V and at 2000rpm it reads 14-14.4V.
It has a really big pulley, but if i change to a smaller pulley will it fix it so it charges at idle? Or will it just blow the alternator and i should replace it?
Re: alternator pulley info help needed
Yes, replacing the over size pulley with a smaller one(stock) will help with your low rpm charging.
