Adjusting the Timing
Old Sep 12, 2006 | 06:57 AM
Blue Jay's Avatar
Ok, SO I borrowed a buddies timing light, and I went to tune my car, and I can't figure out how to adjust the timing on it. Any pointers? I looks like a standard Points and Condensers Distributor, but the cap looks like it is designed to not turn any. its locked into little tabs.
Old Sep 12, 2006 | 09:33 AM
anaik's Avatar
Re: Adjusting the Timing
The cap doesn't turn, the whole distributor does. There should be a lockdown fork shaped piece where the distributor enters the manifold.
Old Sep 12, 2006 | 04:44 PM
Dave89IROC's Avatar
yup
warm up the engine, disconnect and plug the vacuum line to the dist., loosen the dist. hold downm(not much, you want the dist to move, but stay where you move it to)put the timing light pickup on the #1 plug wire, point the light at the timing pointer, and move the dist as required
Old Sep 13, 2006 | 06:57 AM
Blue Jay's Avatar
#1 is the front drivers side on a pontiac block, right?
Old Sep 13, 2006 | 11:19 AM
RAT454's Avatar
be sure to check you point dwell angle before you set the timing...if the dwell is off and you adjust it, it will have an effect on your timing. Get the recommended timing info. Find the pointer/tab on the front cover, then find the line on the balancer. mark them with chalk or a white or yellow crayon.. start engine and let it warm up, disconnect and plug vacum line going to the distributer vacum advance, adjust the dwell, adjust the carb idle, adjust the carb mixture, re-adjust idle, check/adjust timing, recheck dwell, idle and mixture. to some extent each effects the other....
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
ScottZ
Mar 3, 2004 01:34 PM
