6 speed in 69 camaro
Old Sep 12, 2005 | 08:12 PM
69z-28's Avatar
my dad wants to put a 6 speed in his 69 camaro. it currently has a muncie m-20. so the pedals are all there. is there a kit or something that someone sells to put a T-56 in these cars with mechanical clutches, or whats the deal. i know its been done many times before so what do people do? thanks
Old Sep 13, 2005 | 02:01 AM
talos's Avatar
Re: 6 speed in 69 camaro
http://www.6speedtransmissions.com/
http://www.lateral-g.net/tech_articles/ats_t56_install/
Old Sep 13, 2005 | 09:53 AM
Z28SORR's Avatar
If you want to keep the 69 clutch linkage and bell housing, they sell one called the T56 Retro. it has the extended input shaft and late style bell housing removed(there is a plate installed).
Info: http://www.sallee-chevrolet.com/sear...erms=T56+Retro
Old Sep 14, 2005 | 12:10 AM
Bad64chevelle's Avatar
I am doing the same thing in my 1963 Chevy II however will be using a 1996 LT1 Motor and a T56 whenever I can find one for a decent price. Good luck to you on your project!
Jon
Old Sep 15, 2005 | 12:58 PM
jerminator96's Avatar
Jon
What do you call decent?
Old Sep 15, 2005 | 06:41 PM
depends on the condition.
Old Sep 19, 2005 | 06:10 PM
SVThuh's Avatar
Give McLeod a call.. They have an adapter plate that they sell. Makes everything mount up perfect with the old bellhousing. You can even use the LT1 trans, you just have to swap the input shaft out for the LS1 input shaft.
Its a very easy upgrade. I did this in my friends 67 RS and it was a snap.
Old Sep 21, 2005 | 10:00 AM
Blue89Bird's Avatar
http://www.t56kit.com/
Old Sep 24, 2005 | 01:50 PM
BLWN1's Avatar
Good info...
Old Sep 27, 2005 | 06:14 PM
Vegas Mongoose's Avatar
From: A place where Tires, Fuel and Burgers run the show!!
Originally Posted by Blue89Bird
Ditto, Tyler is a great guy and knows his ****. Let them hook you up.
Old Oct 2, 2005 | 04:32 PM
Lt1 and Ls1's Avatar
I am wanting to do the same thing to my 67
Old Oct 3, 2005 | 09:35 AM
stale's Avatar
www.ddperformance.com makes the drop in kit setup for mechanical speedos and clutches, but it looks like their website is down right now.
Old Oct 4, 2005 | 07:44 PM
69CamZZ4's Avatar
I am in the exact same boat as 69Z-28. I am giving thought to this swap also, but I just ordered a dual friction clutch for my muncie, so I was wondering if it is possible to run a T56 with a hydrolic clutch. I went through all the sites about and they all want to sell the the hydrolic parts. Thanks
Adam
Old Oct 6, 2005 | 05:56 PM
Rybar's Avatar
Adam
Yes you can run the T56 hydraulics with your SBC. I would buy a used T56 and make sure you get the hydraulics with the tranny. Tyler at ATS: www.t56kit.com can modify yours or sell you a new GM part. I used his kit and am very happy.
Old Oct 6, 2005 | 11:00 PM
Teetoe_Jones's Avatar
Wow, I haven't been here in a loooooong time.
We can hook you 1st gen guys up with any setup of a T56 you can dream up. Call us to go over your application, and we'll help you find something that works for your budget/intended use. I promise you will not find a better fitting, easier to install T56 kit, than the one we make.
Tyler
sdn1997rs
Dec 30, 2014 08:30 AM
ChrisFrez
Nov 30, 2014 08:41 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
