383 stroker?
Old Jun 30, 2003 | 11:09 PM
r_hodge's Avatar
383 stroker?
im thinking of builing a 383 stroker. my question is what would be the ultimate 383 setup for about 400-500hp for a strong street/strip 77 camaro?
Old Jul 1, 2003 | 12:52 AM
Andrew Coats's Avatar
How much are you willing to spend?
Old Jul 1, 2003 | 01:24 AM
Robbie_97z28's Avatar
LOL Most important question there....
Old Jul 1, 2003 | 08:56 AM
kmook's Avatar
Advanced Tech Moderator
General buildup advise should be asked in Classic Tech for your year. Moving, Thanks.
Old Jul 1, 2003 | 01:34 PM
r_hodge's Avatar
doesnt matter how much right now
Old Jul 1, 2003 | 03:38 PM
2x4's Avatar
2x4
Its pretty easy. Eagle makes some nice afforable complete kits. They have plenty of different options, depending on what your after (n/a, turbo, happy gas). I dont have the Eagle kit, but I figure I'm not too far off from your goals & I didnt have to break the bank to do it. As with any combo, the most bang for the buck is in the heads!
Old Jul 1, 2003 | 06:12 PM
Dirt Reynolds's Avatar
r_hodge, I have a '77 Z/28 with a 413" small block and ported Vortec heads. With the weight of our cars, the bigger the cubes the better. I'd recommend a 406 for your car. Chevy High Performance magazine just did a buildup on a 406 with stock Vortecs and 230 dur. @ 0.050" cam with .480" lift, and 9.5:1 compression. They got 428HP and 525 ft/lbs torque. Great budget engine with big block power.
Dave
Old Jul 2, 2003 | 08:40 PM
Capn Pete's Avatar
428HP / 525 TQ ?! With only a .480" lift cam?! Wow! That makes me really curious what my 383 would have made on a dyno! It was running flat-top pistons, probably somewhere around ~9.5:1, and a .480"/.480" hydraulic cam! The heads were just old cast GM heads, so probably nowhere near as good as Vortecs, but still, those are awesome #'s!!
Anyway, r_hodge, I think a basic 383 build up is gonna cost you at least $3000 - $4000, 'cause aside from the parts, the engine block needs to be machined to make clearances for the crankshaft. Other than that, most of the parts are all typical "350 Chevy" parts, so they're not too expensive.
Old Jul 3, 2003 | 06:13 AM
Capn Pete - the Vortecs have created a new era of 400+HP mild street 350 engines, due to the fantastic fast burn chambers, and high flowing ports. The Vortec is Chevy's best cas iron head - in fact it out flows their 2.02/1.60 Phase 2 steel heads according to the GM Performance Parts catalogue info. You cannot compare the Vortecs to the older 'camel humps'; there simply is no comparison. The Vortecs are awesome heads, - its the reason I went with a set myself.
For the $, its very tough to beat those heads.
Quickss96
Jan 29, 2016 05:56 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
