383 build recommendations
Old Apr 3, 2007 | 01:00 PM
SS Mark's Avatar
I am helping a buddy build a motor, he is trying to stay on somewhat of a budget, I am trying to put together a 383 hydraulic roller that will get between 100-150 shot. I was looking at the partiot performance 225cc heads but am open to suggestions, also need a stroker kit. Any help would be appreciated.
-Mark
Old Apr 3, 2007 | 10:29 PM
ws6transam's Avatar
Oh boy, tough call.
You need to tell us what kind of car your buddy owns, and whether or not this is for road race, street, drag, autocross, or towing rig. Will it be carburated, fuel injected, run on pump gas, or race gas? Does it have to be internally balanced, or can it be externally balanced? Will it use the one piece rear main seal engine block, or the old two-piece RMS?
Old Apr 8, 2007 | 10:23 AM
Ryatt-SS's Avatar
I would go with a rotating kit from Eagle, as the kit features a choice of cast or steel crank, new rods and pistons that are matched. Personally if it were me, I would go with a steel crank, forged 6" I-beam rods and forged flat top pistons. For heads, I would go with either a set of Dart Pro-1 heads or AFR. Does your friend want to run a dual plane or single plane manifold?
Old Apr 8, 2007 | 10:50 AM
CustomSSI's Avatar
Much agreed on the eagle rotating assembly.. We have had good luck with there bottom ends and they are very good priced also.. Let us know if you need some prices on some kits..
Old Apr 8, 2007 | 10:59 AM
Ryatt-SS's Avatar
Gah, where were you when I was building my snall block LOLOL!!!
I have a 355 in my Camaro now, and in a few years after I have beaten it down, I will replace with a big block, more than likely a ZZ-572.
Old Apr 8, 2007 | 11:12 AM
CustomSSI's Avatar
We've been a sponsor on here for well over a year i believe now :-D
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Noct
Jul 14, 2015 01:18 AM
jl1ne
Jul 7, 2015 08:38 PM
