350 question
Old Oct 23, 2006 | 09:00 PM
78Z28350's Avatar
350 question
Hello Im new here. Thought this would be a good place to spend my spare time seing as I am addicted to all Camaros. I have a 78' 350 engine with a cast iron crank. I want to rebuild it and get about 400hp out of it. Does anyone know if it is worth it to rebuild this engine for that kind of horsepower? Should I just look for a 350 forged crank engine to rebuild? Im just trying to figure if I could get 400hp out of this cast iron crank engine.
Thanks, the new guy.
Old Oct 23, 2006 | 09:18 PM
jerminator96's Avatar
Re: 350 question
Ray charles could rebuild a 350 and get 400 hp.
And you really don't need a forged crank if that's all the horse power you want to make.
Just my $.02
Old Oct 23, 2006 | 11:44 PM
markinkc69z's Avatar
Re: 350 question
If you keep your maximun rpm to a sane limit, say 6500 then you shouldn't have any trouble with a turned cast crank, resized rods with good bolts and a line honed 2 bolt block. Spend a bit of your budget on a pair of heads, such as GMPP fast burn heads and select a cam, or have one selected that respects your rpm limit, vehicle weight, gear and compression ratio.
I would build it with federal-mogul L2490F forged pistons, they're only about 500 grams.
Cheap horsepower can come from a windage tray or an inexpensive pan such as a hamburger/trans-dapt 1088H.
Welcome to our board.
Old Oct 24, 2006 | 06:01 AM
78Z28350's Avatar
Re: 350 question
thanks for the tips! my small block rebuild is on its way! Yeah Ill look for those pistons I need to put in some new ones anyway.
Old Oct 24, 2006 | 11:14 AM
Rice Killer87's Avatar
Re: 350 question
Yea thats an easy mark to achieve these days. A set of Vortec (or fast burn if you like aluminum) and a decent 230-ish cam near .500 lift and a good Air-gap dual plane intake and a 750 Holley if fuel mileage isnt a concern. You could even get away with a 650 Holley if you like b/c of only runnin 350 cubes.
Hope that helps
Old Oct 24, 2006 | 02:14 PM
78Z28350's Avatar
Hope that helps
Those are the exact parts I had in mind! I think im going to get fast burn aluminum heads with a dual plane air gap and i WILL use a 750 holley. Im more concerned in power since the car isnt going to be a daily driver. If Im worried about fuel mileage Ill just drive my Saturn!
Old Oct 24, 2006 | 02:20 PM
Now this may just be me but I think a 750 is too much carb for that little motor. I think you would like the 650 better when all is said and done.
Just my $.02 though,
Jeremy
Old Oct 24, 2006 | 02:39 PM
78Z28350's Avatar
Ill see. I got some time to think about it. Ill probably go with a 650 if its too big, now that I think about it 750 is too big for the street. A 750 is unnecessary for my application.
Old Oct 24, 2006 | 03:16 PM
Just keep in mind that your average QJet is between 750-800 cfm on everything from a 305 to a 454. Now they have air valve secondaries but a 750 vac sec holley or BG would work just fine.
Old Oct 24, 2006 | 07:43 PM
78Z28350's Avatar
yeah. well i dont know, im not worrying about a carb yet, i got a 750 on my vette and i have no idea how much hp it has. lol its a 350ci/350hp corvette LT1 but my dad rebuilt the whole engine for street years ago.
Old Oct 24, 2006 | 09:54 PM
Dave89IROC's Avatar
a 750 CFM DP will be fine on a 350, 9-10 :1 comp., fast burn heads and ~.500 lift cam, MIGHT run a shade on the rich side out of the box, but it can be jeted down slightly to compensate if needed/desired
Old Oct 25, 2006 | 06:00 AM
78Z28350's Avatar
yeah because im not aiming for high compression because the vette is very high and doesnt run right on pump gas, even with almost a bottle and a half of octane booster mixed in with a full tank. it "pings" mostly when you WOT it. sounds like static coming from the engine, not good. so i need to put new heads on that this spring and lower the comp ratio.
Old Oct 26, 2006 | 11:16 PM
hotrodguy1986's Avatar
if you really want to keep it simple got to your local advance or autozone and look through a holley book for the systemax II kit. it comes with fully assembled heads, double roller chain, harden push rods, 490/490 lift 245/250 cam, street dominator intake and arp bolt kit. they claim it makes 425hp and if you sweet talk the counter person you can get it for $1300 that is what i bought and it screams.
Old Nov 10, 2006 | 10:52 PM
Dirt Reynolds's Avatar
I would use the Vortec iron head. It is quite easy to get 400+ HP out of a 350 with Vortec heads and a streetable hyd cam. In my own case, I ran a 12.15@ 110.52 on worn drag radials weighing over 3700# race-ready, using home-ported Vortecs, 234/244 Crane hyd FT cam, stock rockers, RPM intake, 1 3/4" Hedman headers and a 3310 Holley on my previous 413. This was launching off-idle with a 2800 stall and 4.10 gear (the car would have been faster with a 3.73). The Fast Burn has a 210cc intake runner and throttle response down low and through the mid-range will not be as crisp or torquey as the Vortec which has a 170cc intake runner.
Old Nov 11, 2006 | 09:47 AM
capncrunch's Avatar
Thumbs up Carb
I knew a guy that built a 'mild' 350 in a '79 Firebird, & he started with the 650 dp holley, tried re-jetting then went to a 750, & tried re-jetting, & finally settled on the 700 (don't remember if dp) which he again re-jetted, until he got it tuned to his build.
I liked his approach, he started where he thought he should be, then broke-in the motor, then he took it to the strip & made his passes, noted the times/probs, & went to work...
In the end, he had a 'mild' 350 that ran consistent 12's, & wasn't going to come apart any time soon!
Don't overlook the simple things, like fuel-pump/lines, distributor-advance, etc. GO CHEVYS!
John
