350 Marine Block
Old Jul 2, 2007 | 01:57 PM
importeater's Avatar
350 Marine Block
Would it be any different building a marine block for a car then a standard block? I'm looking for a 350 and found a marine block locally, just wondered if there were any pros or cons to using a marine block as the foundation for my build. Its just a bare block so I'd start from the ground up using purchased "automotive" heads, rods crank ext..
Thanks,
Craig
Old Jul 5, 2007 | 08:29 AM
mike02z28's Avatar
My dad and I put a 305 from a Caprice and put in a boat. I think a block is a block regardless.
Old Jul 5, 2007 | 03:39 PM
jaykar's Avatar
Marine Block
When using a block out of a boat, couple of things to do.
Make sure you flush and hot tank it real well as most of them were run in lakes and rivers-Sand-Mud-ect. We used
to run filtration systems on them but still silted up after
a while.
Higher end boats were closed loop but still use filters
that need servicing.
Also test for cracks and pressure test. Cold water and hot
iron don't play well togeather. Heads were specially a problem
You can go back and forth sb-bb boat or auto.
HTH
Later
Old Jul 5, 2007 | 09:32 PM
Thanks for the info guys. I ended up getting a 4 bolt 400 and a pair of 4 bolt 350's on the way so I'm pretty well hooked up for the project.
Old Jul 6, 2007 | 10:01 AM
jerminator96's Avatar
How many engines are you going to put in that thing?
What are you planning on building? The 400 block has lots of potential for "fun" motors.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
camaro02DK
Jul 5, 2015 09:04 AM
F'n1996Z28SS
Jun 3, 2015 09:39 AM
sskevinm
Dec 18, 2014 11:16 AM
