289 build up?
Old Jun 25, 2007 | 06:13 PM
henryz28's Avatar
289 build up?
I have a buddy with a 1969 mustang 289.The motor is origional with 200k on it.He wants some power so I toled him I could build the motor for him.What should I do he wants to keep the 289 block; I toled him to ditch it and go 351 but he want to keep the origional motor.What would be a good bang for your buck build on the 289.thanks
Old Jun 25, 2007 | 06:22 PM
henryz28's Avatar
Can I use the 351 heads on the 289 block?
Old Jun 25, 2007 | 07:09 PM
angel71rs's Avatar
You can stick an old style 302 crank in a 289 block to make it a 302. Newer 5.0 cranks won't work since they take the one piece seal. It used to be the hot tip to run 4bbl 351w heads on 289/302s since they had bigger ports/valves. Still remember the casting numbers for the 69-70 "goodie" heads (for small chambers) by heart from many years of keeping an eye peeled for them while junkyard hunting. D0OE & C9OE.
No I'm not a former F@#D guy, I used to get them for cheap cause the junkyard owner wouldn't know they were different from any other SBF head, then sell them to F@#D guys I knew for $. These days, aftermarket heads blow the old factory stuff away.
You can also use 351C heads on a 302 with a lot of adaption to make a home brew Boss 302.
Oh yeah, use 302 rods/pistons with the 302 crank not 289 stuff.
Old Jun 25, 2007 | 07:55 PM
jms's Avatar
jms
The 1969 Mustang didn't come stock with a 289.
302 became standard in 1968.
jms
Old Jun 25, 2007 | 11:58 PM
henryz28's Avatar
Ya I think I got the year wrong.But thanks angle I think I am going to make it a 302 with 351 ported heads with a 4 bbl.What would be a good cam to go with this set up without having to run a stall.Thanks
Novo
Jun 14, 2016 02:58 AM
CARiD
Sep 30, 2015 05:44 AM
pepon214tx
Sep 20, 2015 04:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
reww86
Aug 29, 2015 06:04 PM
