1979 z28 starter
Old Mar 6, 2006 | 09:33 PM
98blckz28's Avatar
1979 z28 starter
My buddy is replacing the starter in his 79 Z but it isnt a stock engine. Could you all tell me where the starter is located... i know that it is a carburated engine but have never seen this engine. Any websites on how to remove the starter or where it is located would be helpful. Thanks alot.
Old Mar 7, 2006 | 10:50 AM
angel71rs's Avatar
Re: 1979 z28 starter
If it's a small block or big block Chevy, it's on the passenger side. If someone swapped in a Pontiac or Olds, it's on the drivers side. Post a pic if you can't tell what it is.
R&R: disconnect battery, note where wires go at solenoid, unhook wires, remove starter brace (if present), remove 2 bolts. Reverse for install.
The starter bolts are specific, don't substitute other bolts if they need replacement. You can find correct bolts in the Help section of parts strore. A lot of times new starter, will need to be shimmed for proper engagement.
Old Mar 7, 2006 | 02:02 PM
94ZRagtop's Avatar
And don't be under the starter when it falls out. Those things are HEAVY.
Old Mar 7, 2006 | 02:49 PM
98blckz28's Avatar
Ok thanks I know the engine is a 396.
Old Mar 8, 2006 | 12:37 PM
Z28SORR's Avatar
And you get to it from under the car. You may have to remove or at least loosen the exhaust. As you have a BB you should get the high torque starter replacement starter.
chstitans42
May 1, 2015 01:03 PM
warmeck
Feb 5, 2015 11:04 AM
ModdedNerd
Feb 5, 2015 04:37 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Jeff1904
Jan 3, 2015 12:00 AM
