1971 fire bird build?
Old Oct 12, 2007 | 07:32 AM
  #16
rob97ss's Avatar
Originally Posted by jerminator96
Holy crap dude! What a pig. Of course if I had my way all sports cars would weigh in under 2500 lbs and have no less than 500 hp, but the world is just not that perfect.
Indeed,his first trip to the track was mid to high 12's 109-111mph.
Old Oct 13, 2007 | 05:16 PM
  #17
IRONFIST's Avatar
If I was your old man I'd get myself a 455, and just not tell anyone
Old Oct 13, 2007 | 05:36 PM
  #18
chief455's Avatar
punch the bore and toss a 400 crank into the original 350 block and don't tell Grind the casting numbers off some good 400 heads,and bingo -
Old Oct 14, 2007 | 02:03 AM
  #19
IRONFIST's Avatar
Arent the 400 cranks the same as the 350's? It's the same stroke isnt it?
Old Oct 14, 2007 | 06:30 AM
  #20
chief455's Avatar
Same stroke - yes, my typo - good catch!
326/350/389/400 = 3.75 stroke, 3" main journals
421/428 = 4.00 stroke, 3.5" main journals
455 = 4.21 stroke, 3.5" main journals
Cranks are sold now with large c.i.d. stroke and 3" journals to fit the small bore blocks with rod/piston clearancing.
I was really kidding as I doubt the 350 could take a + .200" overbore
But many a 455 crank inside a 400 block running around out there already
Old Oct 14, 2007 | 11:36 PM
  #21
henryz28's Avatar
He is going to have to do somthing to the bottom end. Because we just picked it up from the guy that gave it to him yesterday; which said the only thing that was wrong was no carb and broken windshield. Turns out the car has been sitting out for over 10 years and has a rod sticking out of the oil pan.
Old Oct 15, 2007 | 05:36 PM
  #22
chief455's Avatar
why in he world work on the bottom end of a 350 from a 71 bird?
It's the sign he needed to get a bigger/better motor!
If I was you - I'd challange him to build a 400 or 455 with factory heads that will keep up with your car.
It won't be easy for him - you'll be safe fore a long time.
If he has money to throw at it - he still has to get it built and the supporting mods to the car.
It's a dream a long way from being realized
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
carolinacasper
Jul 22, 2015 04:47 PM
RUNMYTA
Jul 15, 2015 07:50 PM
gonzo275rltw
Jul 11, 2015 04:19 AM
