1970 K5 lt1 swap
Old Jun 30, 2005 | 10:15 PM
Deenasty's Avatar
1970 K5 lt1 swap
Hello everyone. I am going to be installing an lt1 into my two wheel drive 70 k5 blazer. I had a couple of questions regarding the install process. First off, how hard do you think its going to be? Do the motor mounts line up? As far as the power steering goes, will I be using the pump from the lt1 setup, or the trucks setup? Any info or suggestions would be greatly appreciated. Thanks For reading!
Old Jul 1, 2005 | 05:58 AM
Kbird's Avatar
Re: 1970 K5 lt1 swap
If the truck had a small block in it before you can re-use the motor mounts. If you have the accessories and belt from the LT1, I would use them on the truck.
Kevin
Old Jul 1, 2005 | 08:49 AM
Deenasty's Avatar
yes truck currently has a small block..
Old Jul 3, 2005 | 03:24 PM
Dave89IROC's Avatar
mounts will line up, the pass side needs to use the bolt hole from the rear A/C compressor brace, use the LT1 brackets and accessories, just custom make a high pressure P/S line(use the new and the old, use high pressure flare fittings to connect)
Old Mar 6, 2008 | 08:26 PM
TurboLsx's Avatar
I am also doing an lt1 swap into a '70 K20 truck. Another question is, will my trucks th350 bolt up to the lt1 and can I use a th350 stall converter or do I need a custom converter? I will be using a GMPP carb intake. Any other tips or hints would be unbelievably appreciated!
Old Mar 6, 2008 | 10:22 PM
Dave89IROC's Avatar
the T350 will bolt up fine, it will use a standard sbc converter
will you be using a standard rear mount distributor?
Old Mar 6, 2008 | 10:53 PM
TurboLsx's Avatar
Thanks for the help. Yes I will be using a standard sbc HEI distributor.
Old Mar 12, 2008 | 10:46 PM
TurboLsx's Avatar
My parts list so far is below...To recap, I am installing a '96 Lt1 into a '70 K20 Chevy truck. I still have to purchase my longtube headers and a carb...I will update again once I start to install the LT1 for those using this post for any future reference.
Parts I have...
'96 LT1
GMPP carb intake
MSD HEI distributor
TCI flexplate
2500rpm stall
cc503 cam
LT4 valvesprings
Old Mar 16, 2008 | 02:52 AM
drpz28's Avatar
I am curious is this gonna be a street /stip truck? I hope so i would like to see what you can do with it. I think the 2x4 is a c5 not k5?
Old Mar 16, 2008 | 02:56 AM
drpz28's Avatar
you can use the power steering pump but you might need to have some new hoses made up. They are not expensive.
Old Mar 16, 2008 | 04:00 AM
TurboLsx's Avatar
I dont think Deenasty is checking this post anymore, I brought it up from a while back. I am actually using a K20, 3/4 ton 4wd truck. It will be a mud/trail truck. Progress wont be very quick, but I do plan on having the LT1 in the truck and running within the next few weeks. I am still in the process of pulling the stock drivetrain.
Noer
Feb 28, 2015 11:29 AM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Camaro90RS
Jul 23, 2002 07:57 AM
